Screw dropped into radiator I was adjusting the position of the radiator cap base of a greyhound on my 33….the screw, lock and flat washer fell off out of sight into the radiator. Need I worry??
Re: Screw dropped into radiator I would think the screw will hang up in one of the passages. The washers on the other
hand may cause a problem in the future . Vic |
Re: Screw dropped into radiator get them all out of there.
Re: Screw dropped into radiator Now to decide what the heck to do next…..flush the radiator……remove it??
Re: Screw dropped into radiator do not run the eng. , pull the radiator, turn it upside down and try and shake it out of there. If you have a long flexible magnet , you may be able to snake it around in there carefully and "find" your lost parts before you pull the radiator, but drain the fluid first. just my .02
Re: Screw dropped into radiator Wait, Tim. Those guys are scaring you without giving any explanation on what catastrophe is going to happen. Before pulling the radiator I would want to get some more opinions. Why wouldn't those things simply fall to the bottom of the radiator and sit there forever? There is probably already some metalic crud down there.
Re: Screw dropped into radiator Drain sufficient coolant to be able to see the top of the tubes. Hopefully, you can then see the missing pieces. If they are ferrous, use a magnet on a flexible stick to retrieve them. Good luck! I always try the simplest method[s] first. If all else fails and you're particularly concerned, you'll need to remove and invert the radiator to shake the bits free. But, honestly, what real damage will they cause; all they will do is sit on top of the tubes, partially obstructing the flow through said tubes.
Re: Screw dropped into radiator Does your radiator not have the baffle in the top tank. in my 33 there is a baffle with the over flow 3/8m tube sticking through.
Lawrie |
Re: Screw dropped into radiator Lawrie, yes there’s a baffle.
Re: Screw dropped into radiator The sky is not falling, all parts will remain in the top tank until flushed out, none small enough to enter the tubes, which is the only way to the bottom tank. Consider if it's time to remove and give your radiator a professional clean-out, or to do a driveway flush-out. Work smart to keep your engine compartment clean while you redirect the top hoses with a sock to catch your parts and other debris while you backflush. Another option worthy of consideration would be to take a cooler full of beer to the front porch and have a friend over to help you drink it.
Re: Screw dropped into radiator Quote:
No worry. The parts will sit in the top and not go anywhere that will cause problems. I'd use a flexible magnet to fish around and see if I could retrieve them but if not I'd forget about it and drive. Terry |
Re: Screw dropped into radiator Agree with Cadillac512 & Kube 100%
Re: Screw dropped into radiator Those parts will sit on top of the radiator tubes. If they are magnetic buy one of these flexible magnets and "go fishing". If non magnetic, drain coolant and tape a piece of hose to the tip of your vacuum cleaner and suck them out.
https://www.ebay.com/itm/25607195957...3ABFBM3uHlpupi |
Re: Screw dropped into radiator I had success with a similar predicament with a modern car buy attaching a 1/2" diameter hose to the end of my shop vac. Stuck the hose in and managed to get the small part sucked out. The nut or washer wasn't going to cause a problem if it stayed in the radiator, but it bugged me enough to give the vacuum cleaner a try after I failed with a magnet.
Re: Screw dropped into radiator Isn't it possible that they could get into the pumps through the upper hoses? If so, could they damage one of the pumps? If you're going magnet fishing, you might have better luck going into the radiator through where the upper hoses are attached than through the cap. IHMO
Re: Screw dropped into radiator I have been in this type of predicament before but by dropping a nut down the air intake of a large diesel engine. I was very lucky to retrieve the nut ( 1/4" ) which had dropped a long ways into the motor. I went to the store and got two large packs of " Double Bubble" chewing gum. Knawed on all of it for awhile and then wrapped it around a loop on the end of a flexible wire. Went fishing and on the first try got the nut out. I was greatly relieved!
Re: Screw dropped into radiator Like they say, "Double Bubble Cures Your Trouble".
Very creative solution. |
Re: Screw dropped into radiator The idea of using a flexible magnet is wise advice.
