snap on door arm rest for 1931 roadster 1 Attachment(s)
When I bought my 1931 deluxe roadster it had Snap-on cloth arm rests on the top of each door (see picture attached). Somehow the passenger side has gone missing. I've checked on some Model A parts website and have not been able to find one. If anyone has an idea where I can buy one (or a new set) please let me know. Thanks in advance.
Re: snap on door arm rest for 1931 roadster |
Re: snap on door arm rest for 1931 roadster Seems like an easy job for a good upholstery shop especially since you have one they can use as a template.
I don’t know about New Jersey, but we have a lot of upholstery shops here in Southern California that do custom work for hot rods. Check around to see if there is a shop nearby. David Serrano |
Re: snap on door arm rest for 1931 roadster The door protector pads are in the current Classtique Upholstery catalog but are a bit pricey at $500. a set for the Stayfast canvas set. I too want a set. Perhaps someone else may offer a set
Re: snap on door arm rest for 1931 roadster Quote:
David Serrano |
Re: snap on door arm rest for 1931 roadster Not available at Mike’s at this time.
John |
Thanks for the link. The only problem with this item is that it is unclear if it has the snaps. The description says - "Great idea to protect your door paint. Clips into side curtain studs. Available in tan canvas. Used on all open cars. Soft napped backing. Fasteners NOT included - Order UF40." Also, when I searched UF40 the same item came up. |
Re: snap on door arm rest for 1931 roadster I can see them not installing the snaps to ensure there is not a mismatch with the position of your current snaps.
