Crank Bearing Problem When removing a shim from between the block and rear crank cap a part of the babit fell out of the cap. How do we repair this? Sure appreciate your help.
Re: Crank Bearing Problem For me the correct way would to have the block bored to accept insert bearings another would be to have the babbit redone, some have been known to use epoxy to re install the cracked babbit, I have seen the results of using an epoxy, however it may work for some people but I have never seen long lasting results, usually the material is flaking off and coming loose from the block and caps and will continue to let go over time and wind up being brought home on a tow truck, but to each their own ,
Re: Crank Bearing Problem The correct way to pull the engine and take it apart. Then bring the parts to a good machine shop that can do Babbett and have new bearings poured and line bored.
The other way to find a good cap and fit it to the crank using the yellow Timesaver. This is best done with the engine out of the car. You will want to pull the crank and inspect the Babbett in the block before just replacing the cap. A third option is to buy a Burtz kit and run that. If you have any mechanical aptitude you can assemble the Burtz kit yourself by just flowing his well written instructions. |
Re: Crank Bearing Problem open your wallet.
i think you will have to pull the engine and do the babbit. the shop that does the babbit will tell you to have the crank checked for straight and the journals turned. they will not do the babbit unless the crank is true. the mains are turned to be true not sized, the shop that does the babbit will line bore it, once it is poured, to match the crank. if needed and it most likely will, i would used new rods with inserts, for this the rod journals are turned to match what ever bearing size is next. OU |
Re: Crank Bearing Problem Also have them check the crank for cracks. If it does not have counter weights you can have them welded on and then have the crank dynamically balanced.
Re: Crank Bearing Problem Quote:
Re: Crank Bearing Problem It depends on the size of the chip that fell out. A small piece can just be left out or set back in and run as-is. Large pieces are another story, replace the cap and fit it in which is tedious, or better yet have the engine re-babbitted. Might as well have it all rebuilt while your at it.
Re: Crank Bearing Problem Berts counterweights cranks.
Re: Crank Bearing Problem Post a picture of the bearing and the piece that broke-off.
| All times are GMT -5. The time now is 04:16 AM. |
