Fabric vacuum lines Looking for mor information on the actual fabric vacuum line if the is anybody can take pictures of the original,and tell the correct size
Thank you Earl [email protected] 610-724-4128 |
Re: Fabric vacuum lines Check this PDF file from MAFCA. It should have hose info on page 74.
https://www.mafca.com/downloads/Semi...A%20Wipers.pdf |
Re: Fabric vacuum lines 1 Attachment(s)
Here is a picture of the original wiper hose from my Victoria.
Re: Fabric vacuum lines Thank you Bill
One more question can you tell me the outside diameter of the tube Thanks again |
Re: Fabric vacuum lines The od of the vacuum line is about .275"
Re: Fabric vacuum lines I bouht some of that fabric vac line for one of my other cars at NAPA (by the foot)
Re: Fabric vacuum lines I was thinking, I recall seeing the fabric covered rubber hose on imported ( not domestic USA) motor cars in the past.. maybe a lead in sourcing.
Joe B |
Re: Fabric vacuum lines I slipped 3/16 wire loom over the rubber hose and it looks real nice. Brattons part # 20320.
Re: Fabric vacuum lines Quote:
| All times are GMT -5. The time now is 04:56 PM. |
