1935-1937 Ford Pickup Door Glass Channel Where along the lower door glass is the metal glass channel installed?
Re: 1935-1937 Ford Pickup Door Glass Channel If the channel has the little "extensions" on it, the glass extends to the edge or end of those "extensions". If no "extensions", the glass extends out beyond the channel on both ends, equally. I hope I'm making myself clear.
Re: 1935-1937 Ford Pickup Door Glass Channel Thanks Lawson.
That makes sense. I have one of each style. I started with the one w/o the guides......it isn’t centered and so I was off a tad bit in aligning with the pin that moves the glass forward. I have a 20’ roll of setting tape. Measure once - cut twice.....or so it goes. |
Re: 1935-1937 Ford Pickup Door Glass Channel Quote:
Re: 1935-1937 Ford Pickup Door Glass Channel I was trying to remember......so many contributions have been made to this hoopie.
but I think you are correct.......... |
Re: 1935-1937 Ford Pickup Door Glass Channel 2 Attachment(s)
Here's a comparison of the 2 styles of channels. The one with extensions lines up with the bottom of the door glass.
