Frame help needed (Everett, WA) Hey everyone, I'm hoping to find in the Everett WA area, someone who has a bare 29-31 frame I can take some measurements from, specifically from the cowl forward. Please do not refer to the Westcott drawing, it contains conflicting dimensions. Thank you
Re: Frame help needed (Everett, WA) Aren’t all frames the same basic measurements, except for body mounting brackets?
Re: Frame help needed (Everett, WA) Likely, could also measure a 30-31. Updated criteria
Re: Frame help needed (Everett, WA) Anyone?
Re: Frame help needed (Everett, WA) Due to the 1930 - 1931 taller radiator, and the 1928 - 1929 shorter radiator changes, there is a difference in the radiator mounting areas between the 1929 and 1930 frames. All of my frames have bodies mounted on them.
Re: Frame help needed (Everett, WA) 13 - Check your Private Messages
Re: Frame help needed (Everett, WA) Thank you for your help Joe
