33 vacuum wipers Had the 33 for a few years now and I've always relied on rainex as the wipers never worked. Decided to check things out.
Motor is Trico KSB 416-2. The only listing I've seen is for a 1940-47. Is it the same used in 1933 or are shaft lengths different ?. Where is there a source for repair kits. Kpar |
Re: 33 vacuum wipers Quote:
Phil NZ |
Re: 33 vacuum wipers Model A kit should fix it
Re: 33 vacuum wipers I purchased a NOS motor from here. https://rebuildingtricowipers.com/ it also came with a 5 year warranty. The motor works fantastic! Very knowledgeable and probably knows exactly what you need.
Sent from my iPad using Tapatalk |
Re: 33 vacuum wipers spare wiper motor i have is a KSB 263 believe its for the 34 Coupe.
Phil NZ |
Re: 33 vacuum wipers 'Clean Sweep' in Redmond, Or Newc
Re: 33 vacuum wipers Keith, how do you know that you will need any parts? Just pull the wiper motor apart and clean it out with some kero or solvent to get any gunk out. Lube the paddle with some light oil or ATF. Dont use brake fluid as some will suggest. Check that the vacuum hose from the manifold is not cracked or leaking vacuum or fit a new hose and put it back together. The removal of the header panel is the hardest job. Regards, Kevin.
Kpar |
Re: 33 vacuum wipers Kevin, I notice you say NOT to use brake fluid. I have always heard that is what is best for this. You always seem to have the proper advice, so I have to ask : What is the reasoning behind your statement?
Re: 33 vacuum wipers KSB 263 is correct. Easy to tell the motor. Has 2 casting spikes to fit in 2 holes on the sheet metal of the body. Not the cover that has cloth on it
X2 Everything good with them. |
Phil NZ |
Re: 33 vacuum wipers 1 Attachment(s)
Tried a test run this morning no go.
Dismantled motor and found this. Maybe I broke it with my shakes or it was already broken. I was going to try and make one on my mill but a bit small for my abilities. Do the kits include this ?. Kpar |
Have sent him an E-mail Kpar |
Re: 33 vacuum wipers Keith, we will be home on wed,I may have one, I have some vac motors in bits
Lawrie |
Re: 33 vacuum wipers You also have to make sure it’s for a RHD car, I bought a no’s one, had it o/hauled, it works great ,BUT parks in the middle of the screen.
Lawrie |
Re: 33 vacuum wipers Kevin: Is that a RHD computer? keyboard may be dirty
Re: 33 vacuum wipers Yeh Terry, right hand drive and made in China. I fixed it anyway. The next time it plays up I will take it down the range and shoot it up with the old 44.40 Win. Regards, Kevin.
| All times are GMT -5. The time now is 07:01 PM. |
