302 eng.W/ c-4 trans to a 53 car what needs to be done for this swap, help needed before i start, like to keep my automatic column shift .
Re: 302 eng.W/ c-4 trans to a 53 car any one ever run a wilson cam in a y-block?
Re: 302 eng.W/ c-4 trans to a 53 car 1 Attachment(s)
Re: 302 eng.W/ c-4 trans to a 53 car 4 Attachment(s)
Re: 302 eng.W/ c-4 trans to a 53 car 2 Attachment(s)
This shows the Lokar ACA-1807 linkage to your Ford-O-Matic column
Re: 302 eng.W/ c-4 trans to a 53 car Quote:
Jeff, I'm in the process of installing a 302/AOD combo in my '54 Ranch Wagon. I have a '54 automatic column. Will the Lokar ACA-1807 linkage work? Per the sites I looked at it is designed for an AOD using a Chevy column. Thanks. |
Re: 302 eng.W/ c-4 trans to a 53 car If you have a question unrelated to the original, start a new post, don't piggyback
Re: 302 eng.W/ c-4 trans to a 53 car thanks for all your help, i am going to stay with c-4 trans ,my friend pulled his AOD trans out because of too many high gears for street use, i will not be traveling much on freeways
If he'd like to get rid of the AOD I might be able to force myself to take it off his hands. ;) . |
Re: 302 eng.W/ c-4 trans to a 53 car I paid for this complete rebuilt 302 ford engine from five star engines and he said he would send it with a rear sump oil pan ,that with my c-4 trans and adapter plates from Bitch's Cool Stuff ,hope it all sits in well
