Dip Stick I am new to Model T's, 81 years old and it is tough to get down to check oil level. Is it worth getting the dip stick kit to check oil from under the hood? Have only had Model A;s for the last 60 years.
Re: Dip Stick Welcome to the T, @ 57 I get the local or the grand kids to do that. @ 81 get the great grand kids.:D That will keep'm occupied and learning.
It might be easier to pop out the floor boards, those petcocks will be right below the passenger side. |
Re: Dip Stick Get the kit and save your knees & Back.
Re: Dip Stick 1 Attachment(s)
We make the Rajo style accessory oil level indicator. With this easy install, you will never have to get out and get under again. ( the Rajo trademark is owned by Kenneth Chaffin and Chaffin’s garage , used with their permission. )
Re: Dip Stick I have a dipstick on both of my Fords. Worth every penny.
Re: Dip Stick On the other hand, getting down and under every time you drive the car will help keep your body limber. "Use it or lose it"!
Re: Dip Stick I'm 86 and use a tool similar to the one in the Snyder's catalog for $9.50. I put a pad down for my knees and don't need to crawl under the car.
Re: Dip Stick Just working the pedals will give you a work out! :) I have known people younger that have installed the dip stick kit. The other option is the site glass. I personally don't know of anyone that has broke one and have used them for many years. Still have to get down but not under to look.
Re: Dip Stick Quote:
Re: Dip Stick Great points and suggestions here but.... you still got to get under there and drain the sediment bowl, fill the various oilers and @ the least do a monthly MTFCA safety inspection.
@ 81 brother you have paid your dues, groom a local kid as an apprentice and sponsor him/her in the model T explorer youth club. It will be the best $15.00 you'll spend this year. Mentors are the most important people in this hobby. |
Re: Dip Stick I have a dip stick on one T and it's real handy. As to the sight glass, one of our members had a rock kick out from a front tire and broke his. We were 20 miles back in the sticks. McGiver would have been proud of that fix. It used up everyone's spare oil to get home.
Re: Dip Stick The sight glass can get clogged with band lint and give false readings.
Re: Dip Stick Back in the day early 60s my fathers 1926 had a dipstick from its time. So easy to
make now with all common hardware. a street elbow on the lower pet cock think it was 1/8 pipe thread and 1/8 pipe which went thru the running board splash pan. Then a common rod into the pipe with a knurled nut on the top. Now you would top off oil just to drip from the top spigot now mark the dip stick as full. thats it all common hardware no more bending over a common accessory back then. |
Re: Dip Stick re plugging up, the centrifugal action of the flywheel pulls the oil out when running so should self clear, besides prudent owners will install a lint screen in the hogs head. More an issue would be plugged vent hole in the cap on the site gauge not allowing the oil back in. If you don't think the oil gets pulled out and have one installed, start the engine and see what happens.
Re: Dip Stick I’d rather exercise at other things than crawling under an old car. So many neat accessories over the life of the tin Lizzie, just to check the oil. It was desirable back in the day, just like today. The Rajo style we make is probably at the upper end $$ of reproduction gadgets, but we sell a lot of them and they are well received. Two out front for the postman today. Original accessory items similar to these are very pricy, many in the multiple hundreds of dollars.
The dipstick requires a hole drilled in the splash apron. The sight glass can plug, and I had one do that about ten years ago. I was on a tour, and kept adding oil, until I probably had 2 gallons in it. As a shameless plug, if anyone is interested in ours, they are $165 ppd, all made in the USA as all our things are. I can share lots of photos of old ads , pictures of ours and easy install pics, too. [email protected] Thanks! |
Re: Dip Stick Alright Mr. Morsher I'm sold, will send you an email and order in the a.m.
My Dad was from Racine and to this day we still enjoy the O & H kringle. If you don't know what that is fellas your missing out:D |
There are a lot of talented "T" folks in the O-H-I-O state, Brent Mize and Douglas Dachenbach to name a few. |
