Good bearing? 2 Attachment(s)
Ok so I am putting together a spare tranny and since I am putting new gears in, I thought I would check out the bearings. This is what I found: left is from the input shaft, center is long one from cluster and then short from cluster. I think the long cluster is an original and the other two are repops. Don’t remember the history ask got it at a swap meet years ago. Any ideas?
Also, is the cluster gear toast? The pitting is only on one side of the teeth, so if that is the back up side I won’t care as much. Just curious, on these small surface would JB Weld hold up? I think it now just a back up gear and I need a new one. I think it will work but just as an emergency gear. Mike |
Re: Good bearing? 'Art',
If you don't have a radio in the car, that cluster gear will certainly sing to you. jb |
Re: Good bearing? Looks like from here I would replace gears
Re: Good bearing? Yeah that is what I was thinking. So it will sit on a shelf until I can get another. Are they made in the USA or China now?
Mike |
Re: Good bearing? You could make a lamp out of that cluster gear. I chucked mine and it looked a little better than that one, but not by much.
Those bearings might be okay? Hard to tell from the picture. I think Bert's has some NORS ones if you need some. I know MARK makes the sliding gears, I assume they make the cluster gears as well. Now, if they make them in NJ or outsource production overseas is beyond me. |
Re: Good bearing? Check in the swap meet site, I think I saw someone selling gears.
Re: Good bearing? Quote:
Re: Good bearing? At the Rouge transmission assemblers hand fit sliding gears to cluster gears,one spot where Ford didn't master interchangeability. Your parts are junk,btw..
Re: Good bearing? JB weld on transmission teeth or other moving parts ??
Re: Good bearing? Hey one can dream can't they:)
Re: Good bearing? He must have found some as I ordered two of each. The shorts were NOS and the longs were used originals. Once I get those then all I will need is a cluster gear and I will have the quietest tranny on the block!
Thanks for all of the tips. Mike |
