Apart from Ford, who else made hi-comp police heads back in the day A friend has a stock looking head with the same (or very similar) combustion chambers to a police head; it has various numbers, like part numbers, in small font cast on the top. Did Napa or other such companies offer stock looking police heads back in the day?
He wants $200 for it so thinking of buying rather than going for a Snyder. |
Re: Apart from Ford, who else made hi-comp police heads back in the day Information on heads here may help!Model 'A' Ford Garage ~ Model 'B' Ford Garage
Re: Apart from Ford, who else made hi-comp police heads back in the day Quote:
Thanks, here it is http://www.fordgarage.com/pages/head...ssionratio.htm |
Re: Apart from Ford, who else made hi-comp police heads back in the day |
Re: Apart from Ford, who else made hi-comp police heads back in the day 1 Attachment(s)
Two things to check. Be sure that it hasn't been milled enough to allow the piston to hit the head (like the one in the picture) and look for cracks. Pay particular attention to where the arrows are in the attached picture. You should probably run a Model B head gasket to match the shape of the combustion chamber. How about a picture of the other side?
Charlie Stephens |
Charlie, do you mean that the head I posted above has been milled too much, or the head you posted? I put a photo of each side above. |
Charlie Stephens |
Re: Apart from Ford, who else made hi-comp police heads back in the day .040 is a good quench factor,quench is the space between the top of the piston and the head.
Re: Apart from Ford, who else made hi-comp police heads back in the day 2 Attachment(s)
Attachment 428562
Attachment 428563 Quote:
Charlie Stephens |
Re: Apart from Ford, who else made hi-comp police heads back in the day Todd Buttermore's Snyder heads are high quality new castings,for 100 bucks more what you buy will be crack free,buying used period stuff is a crapshoot..That being said,some used period heads are cool,like a winfield red 7 to 1 :)..Todd is making these now too..
https://i.imgur.com/Jj3Sf7C.jpg?1 |
Snyder's heads are great except for the fact they are sold green...must be milled before installing which adds another $50 plus time and hassle. If Snyder's were buy and bolt on I may have gone for one instead. |
Re: Apart from Ford, who else made hi-comp police heads back in the day All that was necessary with the 5.9 heads that I use was to bolt them on and torque until it held .
Re: Apart from Ford, who else made hi-comp police heads back in the day Snyder heads are plug and play..bolt the on out of the box.
But lets play..say you had to shave one,still better than buying a used one if its cracked |
Re: Apart from Ford, who else made hi-comp police heads back in the day Thanks Jack for the info !!!
Re: Apart from Ford, who else made hi-comp police heads back in the day I took my 6:1 Snyder head to the NAPA machine shop and the guy was surprised at how straight it was.
Re: Apart from Ford, who else made hi-comp police heads back in the day Wasn't the problem with crooked Snyder heads corrected back when it was discovered? I thought I read about that a while ago.
Re: Apart from Ford, who else made hi-comp police heads back in the day Discussion about Snyder's heads issues here:
https://www.fordbarn.com/forum/showt...green+head+tod "I would have it checked for straightness, as not only my one, but several others I’m aware of weren’t flat. Several lost gaskets." "I bought a 6.0 head from Snyders and the shop told me it was far from straight." |
Re: Apart from Ford, who else made hi-comp police heads back in the day Snyder has been in business over fifty years,Buttermore is casting all kinds of stuff right now.I doubt that Snyder wouldnt make good if in fact you found you had recieved a bad head from them..
"I also set the head on my bare block with out a head gasket and it rocked back & forth! It was warped several thousandths & had to be milled. Snyder's offered to ship another head but the first on took three weeks to arrive. After talking to them I had the head milled & sent them the bill and was reimbursed." Back to the topic of my decision to buy an original hi-comp for $200 rather a new Snyder for $325...the numerous reports of warped green heads, such a the thread above, played a role. How can I ignore such information when making a decision? The other thing in my case is that the head I'm buying is being supplied by the engine guy who's doing my engine...if the head is cracked and fails he will also hopefully step up to the plate. |
