How to remove the U-Joint from my Trans? 1 Attachment(s)
Hello All!
I need help in figuring out how to remove the U-Joint from the back of a 1947? side shift 3-speed? If you could direct me to a u-tube or a simple tutorial would be fine too! Thank you in advance! Chris Kennedy |
Re: How to remove the U-Joint from my Trans? Use a 9/16 socket on an extension thru the splines, work your socket around until it fits on a bolt head, turn CCW until you remove the bolt, then slide the ujoint from the trans shaft. Put your trans in low or reverse to help prevent it from turning. Good luck!
Re: How to remove the U-Joint from my Trans? i've always been able to get on it with a box end wrench
Re: How to remove the U-Joint from my Trans? 1 Attachment(s)
I've always gone in through where the arrow indicates.
Hey Chris....Follow the advice in post #2 just below your post. Here is a picture of the bolt head that you are aiming for INSIDE the U-Joint. Easy Peasy! DD https://www.fordbarn.com/forum/attac...4&d=1586747740 |
Re: How to remove the U-Joint from my Trans? Hint --- Save the Special washer- Thick and Dish shaped.. J. A. S.
Re: How to remove the U-Joint from my Trans? Are you guys sure he's pulled the torque tube/rearend back?
Re: How to remove the U-Joint from my Trans? That was my thought too. Jack E/NJ
Re: How to remove the U-Joint from my Trans? Quote:
Re: How to remove the U-Joint from my Trans? Sometimes a little extra information sure helps clarify a situation.
Re: How to remove the U-Joint from my Trans? V8COOPMAN;
To add to your great explaination, how and why don't people search Google before they ask questions? Everyone is asking for the easy answer. Or better yet, why not search for manuals or service books before asking -- What do you use? I wonder if there is a Forum for how to tie your shoes? Oops, forgot, I could have Googled that before asking that question. |
Re: How to remove the U-Joint from my Trans? What kind of oil should I use in my flathead?:D
No description; New? Old? Rebuilt? Stock? Street use? Racing?:rolleyes: I think it may be new guys trying to ask an innocuous question in an attempt to fit in. |
Ken |
I know that in spite of being a pretty fair speller, my dumb pride still makes me check with Wiki a LOT to keep from screwin' the pooch more often. Hell, I even find myself making prolific use of the 'Barn's own "search" function pretty regularly.....imagine that, huh? DD |
Ya know, that Ken dude kind'a has a pretty decent outlook about STUFF! Having a clue as to what might be interesting....and what's not, is key! DD |
Man, if ever there was a perfect example....! DD |
Re: How to remove the U-Joint from my Trans? "To add to your great explaination, how and why don't people search Google before they ask questions? Everyone is asking for the easy answer.
Or better yet, why not search for manuals or service books before asking -- What do you use?" Exactly what do you think Ford Barn is? Better yet, what do you think Google is? You obviously got some confusion going on there. Ford Barn is here as a resource ... even for the dumbest among us. Ask here first. I can refer you to some "first class" early Ford V8 information on Google that is completely wrong. Stop telling guys not to post here because this is their first stop for shopping. You have no idea of the disservice you are doing to this site. (By the way, those of you complaining about lack of information offered by a poster, ask questions.) |
Re: How to remove the U-Joint from my Trans? Same here. If everyone could google the answer, what use is a forum?
