The Ford Barn
-   -   7 tooth steering box (https://www.fordbarn.com/forum/showthread.php?t=276086)
wkuehnis 01-30-2020 07:19 AM
Hi,
I have a steering column maybe from 1929. It has no oil plug, so it uses only grease. it has 2 grease nipples.
It has a black splined steering wheel.
I don't understand the following:
I insert the 7-tooth sector and connect it with the steering worm gear on the steering shaft.
When I turn the steering wheel now, then I can turn the pitman arm, but if I fix the pitman arm, then the steering column moves upwards and comes out of the upper bushing.
Is there no fixation for the steering column in the steering housing, because only the sector should turn and the steering column should only rotate.
I know, at the lower end, I have to install the spider with the spring and it's fixed on the light switch rod with the Spider retainer, but this is not designed to handle such a high load.
What am I missing ?
Thanks for help
Willi
ryanheacox 01-30-2020 07:47 AM
Re: 7 tooth steering box
I've never been inside a 7 tooth box but there are a few threads on here that are recent about it. From what I gather you need to play with the shims on yours to reduce the shaft end play. The shims are between the bottom of the box and the plate where the light switch attaches.
Also, the grease fitting that is on the steering box takes oil, not grease. Just unscrew the fitting and add oil. The fitting where the sector shaft goes through takes grease, good for the bushings and helps reduce oil leakage.
rocket1 01-30-2020 07:54 AM
I would suggest getting Les Andrews book,the pictorial breakdown on the 7 tooth steering box shows a thrust bearing above and below the worm.possibly someone on the barn could post the picture.
alexiskai 01-30-2020 08:57 AM
https://www.brattons.com/media/catal...h-steering.jpg
alexiskai 01-30-2020 09:01 AM
It's not real clear from the schematic, but the bushing labeled 14 goes above the worm gear and the one labeled 29 goes below it. The bearings labeled 13 go on either side of the worm. That's what holds the whole thing in place and allows it to turn.
Steve Plucker 01-30-2020 10:41 AM
Make sure when restoring the 7-tooth column that you use the correct #13 bearing as Ford made a change sometime in the assemblies (bearings), diameter wise, of these columns. These are the same bearings utilized as the thrust bearings on the front axle.
Pluck
Ranchero50 01-30-2020 08:50 PM
Originally Posted by wkuehnis (Post 1846671)
Hi,
What am I missing ?
Thanks for help
Willi
Your axial clearance is too large on the steering shaft between #14 and #30. The worm is moving in that clearance and that's why the steering wheel is moving in and out.
On mine I put it together without the gasket (used permatex) and that eliminated the looseness that mine had.
wkuehnis 01-31-2020 10:24 AM
Thanks you all,
When I disassembled it, this 2 king pin bushings were not in place. Now I understand it more and more. Soon, it will be running!
Thanks bringing me to the right way.
Willi
