The Ford Barn
-   -   Dipstick question (https://www.fordbarn.com/forum/showthread.php?t=271030)
WQ59B 10-16-2019 08:04 PM
Dipstick question
1 Attachment(s)
Have (as far as I know) an un-rebuilt '46-48 59AB 239, with this dipstick. All stock (with a few older parts, such as the diver's helmet- might have been from the original truck: 1940). No oil filter.
Someone in the past was rather vehement about re-stamping the stick. Level is just shy of the new mark at 4 quarts.
Any opinions of the new mark, the 4 quarts, or if I should run 4.5 qrts?
34PKUP 10-17-2019 01:23 AM
Re: Dipstick question
Obviously the wrong tube/indicator.
If when filled with 4 qts it's shy of the mark then just make a new mark at that point.
There is no reason to over fill it.
Mart 10-17-2019 04:50 AM
If you have a mechanical oil pressure gauge, fill it with 4 quarts and see if you get any oil pressure dropoff when cornering sportily. Uphill too if possible. See if you get any dropoff after 10 mins at what you would consider highway speed (60mph ish).
If you do see any pressure reduction that recovers after slowing or going straight ahead, then the level is too low and you can add some and see where it comes on the stick.
If all seems well with it set to 4 quarts then you know where that is on the stick and you can monitor it and maintain it at that level.
Overfilling should be avoided, as should allowing the level to drop too far (for obvious reasons).
I had the two scenarios I described above in two of my cars and had to drain, refill with a known quantity and remark the stick. That is probably what a previous owner did in your case.
Mart.
WQ59B 10-17-2019 06:40 AM
Well, its the 2-ton COE, so cornering sportily and 60 MPH is beyond reach. On initial start-up, mechanical ‘thermometer’ gauge shows PSI in the low 30s. That will drop (at idle) to the low 20s once warmed up. Not enough seat time yet to report on at-speed pressures.
I read a number of discussions here on proper oil capacity, with the 2 camps divided between 4 & 5 qrts WITH filter, which makes me wonder on proper capacity without one.
WQ59B 10-17-2019 07:07 AM
I just changed the oil last month, let it drain a good half hour while doing other tasks, and put 4 qrts back in. Next-day level (after idling to warm the prior day) was about 1/8-in below the new mark... so not sure what the PO did here. I don't see a 'problem', just looking for some reassurance.
big job 10-17-2019 10:26 AM
OK my fresh 59A I put 5 qts per orange engine book. My glove box manual from a 1942 says no filter 4 qts. I put the oil in the valve chamber so all nooks and crannies are
full and valves guides etc. I spun the cam with a drill no pressure five more qts oil
press 60 psi spun with drill, check oil full. Since I have 3000 miles and it still needs
5 qts. so whats it going to be. this is original, nobody messed with dip sticks. but my
later F6 Trucks 5qts plus one for the filter. Then my F8 is 9qts and one more for filter.
crazy Sam
Ol' Ron 10-17-2019 12:02 PM
The tube that holds the dipstick is a 1.2: nf thread. Go to the junk yard a get a modern dipstick with a nice yellow handle. Get a piece of 1/2" thin wall tubing and thread it into the pan , mark it for a convenient location and cut it off and bend it into position. On you next oil change you can mark your stick
51 MERC-CT 10-17-2019 01:55 PM
The yellow handle makes sense (I have one) but a yellow band around the tube makes more sense (so you can find the hole ):D:)
