The Ford Barn
-   -   Rear Hub Grease Seal Removal Tool (https://www.fordbarn.com/forum/showthread.php?t=259400)
Steve Plucker 02-18-2019 05:41 PM
OK...We have a couple of tools that will let us install the Rear Hub Grease Seal...But do we have a decent tool that will let us remove the seal effecently?
I spent about an hour trying and figuring out a way to remove the seal...Got one, got 6 to go and they seem to be a B%$#@!
Tom Wesenberg where are you?
Thanks.
Pluck
ursus 02-18-2019 06:20 PM
Re: Rear Hub Grease Seal Removal Tool
Lay a piece of plywood on a concrete floor. Hold the drum with seal side down at belly button height and let her drop evenly to the plywood- the sudden impact of the bearing should knock it loose. Repeat if necessary.
160B 02-18-2019 07:30 PM
3 Attachment(s)
Steve here are photos of a tool for split rims that I use to remove rear axle seals. I put the drum in a vice and pry the seal out.
redmodelt 02-18-2019 07:44 PM
I do what ursus suggest. If the drum is coming off anyway which most of the time it is anyway for new drums, I go outside and drop on the cement. For sure if you drop on cement you want to do outside, it is loud. (: Don't forget to take the lock ring out first!
Tom Wesenberg 02-18-2019 09:38 PM
I was at Harbor Freight yesterday and saw a tire tool that was shaped like your tool pictured.
Tom Endy 02-18-2019 11:47 PM
1 Attachment(s)
The attached photo was posted on fordbarn a couple years ago by someone else. What you do is cut off the tapered end of an old axle about six inches long. Slip into the drum and use is as a pedestal to pry against.
Tom Endy
PC/SR 02-19-2019 12:12 AM
The dropping technique works. I slam it down on a towel laid on the the concrete shop floor. Few slams does it. The towel cushions the edges enough to avoid damage to the drum.
1927Tudor 02-19-2019 12:34 AM
Tom Endy
X2 on Tom’s method. Any cylindrical piece will work... I’ve used a piece of wooden dowel, you just need a base for the fulcrum for your prying.
larrys40 02-19-2019 11:31 AM
2 Attachment(s)
I use a KR Wilson BV81 hub seal/bearing remover tool. There are no current reproductions made. I've thought about reproducing it as it has been incredibly handy throughout the years. There was one for passenger car and light truck and another 3 legged one for large truck.
In lieu of the KRW tool I like Tom's pry suggestion best. I've seen many bearings ruined by folks who pry on the upper bearing cage. some put screws into the seal and use a puller or pry as well. some seals come easy, some hard. I find that sometimes some of the repro seals are to large on the OD and need to be surfaced down for a better fit. For the installer tool for the seal Jeff at Brattons attended one of my KR wilson seminars back in 2014 and he now has a new version for sale.
I believe they still have them available
Larry Shepard
Drive Shaft Dave 02-27-2019 01:31 AM
Tom Endy
I have used the Tom Endy method for years , works good.
Steve Plucker 02-27-2019 11:28 PM
Thanks guys...got them out...been snowed in but I had a tool I forgot about in my NH3 days in a tool box...It worked along with a nice fat washer.
Great ideas!
Pluck
