Holley 94 fuel inlet fittings...? 1 Attachment(s)
Trying to clean up a lot of unsightly fittings and some leaks on my flatty and wonder if their isn't a way to cut down on all of these adapters and just have one fitting to go into my holley 94 carb (and fuel pump to carb too) w/ 3/8" (assume?) male flare to 3/8" (or 5/16") hose barb? 3 adapters per fitting seems in excess...:o In doing some research this seems to be a common issue and the only thing I can come up some old posts with a weather-head fitting from napa? Any tips :confused:
Any info appreciated, thanks |
Re: Holley 94 fuel inlet fittings...? www.parker.com, brass fittings
Re: Holley 94 fuel inlet fittings...? Edelman 842550..........google it
Charlie ny |
Re: Holley 94 fuel inlet fittings...? Quote:
Thank You Charlie, got one off of amazon (all they had) and another from Oriellys |
Re: Holley 94 fuel inlet fittings...? 1 Attachment(s)
Edelman 842550 photo if anyone is interested.
| All times are GMT -5. The time now is 05:07 AM. |
