The Ford Barn
-   -   1932-34 truck dashlight (https://www.fordbarn.com/forum/showthread.php?t=256694)
A V8 Al 12-27-2018 04:01 PM
Could someone tell me where the bulb socket bracket mounts. It has a single capture nut and the wire from the socket to light switch is 13" long and is 2" from the left side of the dashboard. Thanks in advance for your input.
34pickup 12-27-2018 05:43 PM
Re: 1932-34 truck dashlight
If it what I think you are talking about, it mounts to the center dash screw.
DavidG 12-27-2018 07:41 PM
Only '33-'34; the '32 socket is integral with the instrument panel, which is separate from the dash.
totto 12-31-2018 02:46 PM
As mentioned, mounts to center dash screw for '33-'34.
Henry
