32 "B" Block Not Rebuildable ? Looking for a "B"NOT rebuildable Engine Block ? Maybe Casey the Crack fixer from Ma,. info as he may know of one. Just for a mock up purpose. ? Thanks for any help. Kerk
Re: 32 "B" Block Not Rebuildable ? Depending on what you're trying to mock up, an A block would work. Subtle differences.
Paul in CT |
Re: 32 "B" Block Not Rebuildable ? A guy sitting on a mound of junk blocks would not know where Kirk is located. Might it be a secret? Some of the "subtle differences" will make Model A block as mock up, less useful. Oil pan and candidate trans may be a problem for an A block. Where B running gear is used, kind of frame makes a difference. However, where Kirk may already knows all this, we're left to sort it out for no use. Good Luck: Fred A
Re: 32 "B" Block Not Rebuildable ? Block'' I am in Massachusetts and it will be for a display so needs to be a "B"" Thanks for the replys. kerk
Re: 32 "B" Block Not Rebuildable ? Contact some engine rebuilders and junk yards they my be able to give you a lead.
