Y block fuel filter Looking for a replacement fuel filter element for my '60 ford Y block 292. My research calls for a motorcraft FG-32 which evidently is obsolete. What is everyone using for a filter element and where can I get one?
Re: Y block fuel filter 1 Attachment(s)
Here is a C0AE 9155-A (FG-6) inline with fittings. Close? |
Re: Y block fuel filter I think, he said about PASS CAR
Re: Y block fuel filter Looks like Motorcraft #FG32 crosses to Donaldson # P552470.
Check out this link,, near the bottom it shows cross reference: https://www.dieselequipmentinc.com/products/p552470 |
Re: Y block fuel filter Quote:
Maybe you can attach a photo... Depending on what model vehicle it is different filters could have been used when new. And unless the vehicle has been kept original for 58 years it could easily have something else for a fuel filter. |
Re: Y block fuel filter Attaching a photo of what you have now would help.
Re: Y block fuel filter A 56 is probably different but I have the glass bowl that is on the bottom of the fuel pump and the filter element is in the bowl.
Re: Y block fuel filter '60 pass. car. Fuel pump has a canister filter housing screwed on the bottom with , I assume a filter element inside. maybe it is a canister filter. just noticed it yesterday and was hesitant to remove it without knowing if a replacement is available. I have a large in-line filter installed before the carb so I suppose I could leave the pump filter off, if it was just a filter element inside the canister, if it was no good.
Re: Y block fuel filter There is a filter element in the screw on cannister. they are available at most parts stores, some may have to order it. I do not know the Part # off hand , but that same set up is used on many fords up into the '70's and '80's. It is also used on a lot of heavy equipment. I used to have to change them on our boiler trucks here in Alaska that we use to clear frozen culverts in the winter. granted we were using it for diesel fuel, but the filter does not know the difference between diesel and gasoline
FYI- The FG-33 was a complete changeover kit used when FORD began changing from the canister style filter to the inline style. It should also take the FG-1 element if that is what is on the car. The kit mounted on the frame rail adjacent to the pump. |
Re: Y block fuel filter On the 312 in my 54 Ford, I have a FE fuel pump with the canister filter on it.It is off a 360 CI truck, mid sixties. I have spare filter element. The manufacturer is ProGauge, part # CG20. On the box it list it as a replacement for the following:
AC - GF157 WIX 33271 Hastings GF6A Purolater F21115 There is a sticker on it with a C4AZ-9365-B number and says Ford licensed product???? The number may be what your looking for. Check the numbers on ebay to see if they have your car as an application |
IF the pump canister element is 1962/ it will take- NOTE- C4AZ 9365-B (FG-1-A) seems to be the service replacement for C4AZ 9365-A) If the pump canister is 1962 (mid-year break) and earlier, it will take B6T 9365-A (FG-24). |
Re: Y block fuel filter thanks guys, I'll do some searching and see what comes up.
Re: Y block fuel filter A picture of your filter sure would help.
Re: Y block fuel filter The glass bowl, is there a spring under the element to hold it snug up against the intake hole so that gas is drawn through the paper element?
My glass bowl is deep enough that it just falls down about 1/4". Perhaps it was replaced, but the bail will never hold a shorter bowl tight. |
Re: Y block fuel filter 4 Attachment(s)
Is the fuel filter part of the fuel pump (photo 4) or something else? It's possible the filter element is a friction fit on the shoulder of the Inlet at the center of the housing. (photo 1) The gasket for the glass bowl will hold the filter up in place but it should be carefully centered to avoid unfiltered fuel exiting the housing. (photo 2) |
