The Ford Barn
-   -   Gas peddle & footrest escutcheon 's (https://www.fordbarn.com/forum/showthread.php?t=249903)
Rusty Homestead Fl 08-19-2018 09:59 AM
Late '31 Coupe. Does the flat side of the gas peddle & footrest escutcheon's go up or down. Thanks
figment 08-19-2018 10:02 AM
Re: Gas peddle & footrest escutcheon 's
Down
Rusty Homestead Fl 08-19-2018 10:09 AM
Thank you "figment".
GerryAllen 08-19-2018 10:15 AM
I am just sort of a regular guy and new to Model A's. What is an Escutcheon,
if all else fails I can use the word at our next Club meeting.
Gerry, Birch Bay Wa
cpf240 08-19-2018 10:37 AM
Escutcheon is a fancy word for the trim piece that goes around things like the window crank handle, etc...
Ed Saniewski 08-20-2018 05:58 AM
I thought the gas pedal had a rubber seal nailed to the floor board with 3 tacks? What dose the escutcheon look like? Or are you talking about the foot rest base?
Rusty Homestead Fl 08-22-2018 11:20 AM
1 Attachment(s)
Actually Both Ed. The one on the left is the accelerator floorboard cap that covers the rubber grommet and the one in the middle is the footrest mount. Sorry I wasn't too clear on my question. The one on the right is what I found in a box of parts that came with the car. Earlier foot mount as I understand (?).
kimeccles 08-22-2018 07:15 PM
Rusty,
The foot rest base plate flat side points to the accelerator pedal, or to the left side.
according to Section 11-8 Judging standards revision 2016. Edited to add that the middle one you pictured is correct based on my mid-1930 but with flat side to the left.
There is also a thin rubber washer that tacks for the actual accelerator pedal as mentioned above.
figment 08-22-2018 07:24 PM
The foot rest base on the right with four screw holes is for the early Model a's
Rusty Homestead Fl 08-22-2018 09:18 PM
Thanks Kimeccles. Guess it's time to get some updates on my 1989 Judging Standards. My section 11 only goes to '6'. lol
