The Ford Barn
-   -   Is a 21A flathead desirable? (https://www.fordbarn.com/forum/showthread.php?t=24065)
Hitchhiker 12-26-2010 01:02 AM
Is a 21A flathead desirable? It's out of a 1941 ford passenger car I believe. good or bad? what are the draw backs of it? thanks
mike@earlyfordstore 12-26-2010 03:43 AM
Re: Is a 21A flathead desirable?
It is like a 59AB except it has a smaller bore, 3 1/16" compared to 3 3/16".
41Fordor 12-26-2010 08:53 AM
Can easily be bored to 3 3/16 (239 standard) with the sleeves removed. With the smaller heads this gives a good compression ratio. That's what I've got.
Walt Dupont--Me. 12-26-2010 08:58 AM
I've built alot of those engines. Remove the sleeves and bore the block another .045 and use 8BA std. pistons. Use 59AB heads gaskets and the 41 heads. Makes a nice little engine. If you want to put a cam and dual carbs and a better set of heads it make a good little streete engine. Walt
Ralph Moore 12-26-2010 11:18 AM
I've got a couple of those engines and was wondering about the sleeves. Were the sleeves put in at rebuild because of wear, or did Ford put these in from the factory? The way your talking it sounds like they were all sleeved at one time or another.
Kahuna 12-26-2010 11:24 AM
Hmmmm, Walt. 59 gaskets on 21 stud engine? Little too much Egg Nog and Rum last nite? heh heh
Regards
Jim
oldford2 12-26-2010 11:33 AM
Hmmmm, 21-a engine is 24 stud. I don't think it was Walt that was drinking the rum. LOL John
Gumpy 12-26-2010 11:41 AM
yes a 21 a is desirable ....I believe in making the most hp out of a stock looking engine....look what simca and the french came up with ....the v8 60 powerhouse!!
Ol' Ron 12-26-2010 12:16 PM
Yes the engine came with thin sleeves from the factory. The simple solution here is as WALT says, 86 the sleeves bore .045", late pistons, use 59 head gaskets and 81a heads. Very inexpensive way to gain a fair amount of torque.
Interchangeability, lov that Flathead.
Kahuna 12-26-2010 12:56 PM
Talk about being a bit hung over, I read it as 21 stud, ha ha
Hitchhiker 12-26-2010 02:28 PM
Thanks everyone. Sounds like it will be a good start to a nice street motor for my AV8. I didn't know you could remove the sleeves. concerning the 8ba parts. would it be a good Idea to use the entire 8ba rotating assembly? Mainly for the insert bearing rods? or is that a waste of time. thanks. Matt
Walt Dupont--Me. 12-26-2010 04:10 PM
Matt, the 8BA crank will fit right in the 39 up block. You'll have to get the aluminum seal retainers for the rear seal. Alot cheaper rod bearings. Use the main bearings that goes with the block. Walt
Hitchhiker 12-26-2010 06:58 PM
maybe I should go ahead and source a merc crank. or a scat rotating assembly.
41panelmark 12-26-2010 08:01 PM
If you can find a crank go for it, my old 41 runs very well with a Merc. crank, Ike cam and adjustable lifters along with Merc pistons. Outside looks very stock. Lots of power for my old panel.
Have fun!
