34 cowl lamp mounted outside mirror Is there a source yet for a 34 behind the cowl lamp mounted outside mirror?
Re: 34 cowl lamp mounted outside mirror I also would like a pair if someone knows a source.
Re: 34 cowl lamp mounted outside mirror carguybill, Since nobody makes them anymore maybe you will? I want some too!
http://www.fordbarn.com/forum/showth...+light+mirrors |
Re: 34 cowl lamp mounted outside mirror Me to !!
Re: 34 cowl lamp mounted outside mirror I would be as well.
Re: 34 cowl lamp mounted outside mirror Ditto all above
Re: 34 cowl lamp mounted outside mirror OK, I understand first hand, the need for an effective outside mirror for our '33's and '34's and I will move ahead to manufacture such an item. I do not want to bother to make an item that is commercially available.
I assume that most owners are like me and would like to have a mirror that both looks period and is effective but I would prefer to make a product that is close, at least, to a mirror that was offered from the factory or was an approved Ford accessory. I am not aware of any mirror that was supplied from the factory or as an accessory. If anyone knows of such an item I would like to see one or, at least, have a picture of it. |
Re: 34 cowl lamp mounted outside mirror It's a great idea! I'd be interested in purchasing such a mirror or two as well....
Re: 34 cowl lamp mounted outside mirror I have a clamp on mirror on my 33,its great.
It mounts onto the front edge of the for,BUT does not clamp up in the usual way with screws that stick out inside,it has no screws protruding to damage the paint on the door and the door pillar. I was going to make another but got too busy, I will do a drawing if any one is interested Lawrie |
Re: 34 cowl lamp mounted outside mirror Quote:
Kpar |
Re: 34 cowl lamp mounted outside mirror Karl, the one on my 33 does NOT mess up the paint,as I said it has a funny clamp arrangement that does,t have any screws digging into the paint.I will post a pic .
Lawrie |
Re: 34 cowl lamp mounted outside mirror [IMG=http://imagizer.imageshack.us/v2/150x100q90/923/6OlCcn.jpg][/IMG]
My only concern is what keeps the arm from turning in the wind "at speed"? |
Re: 34 cowl lamp mounted outside mirror 1 Attachment(s)
[QUOTE]
My only concern is what keeps the arm from turning in the wind "at speed"?[/QUOTE] When I showed our engineer a photo of this mirror bracket that mounts to the cowl light your comment was exactly what he said. Not exactly sure how we will address this issue yet but we will design the fix into any mirror we produce. Attachment 301095 |
Re: 34 cowl lamp mounted outside mirror I had planed to make a pair and I thought about a small pin next to the hole or key way for that purpose. I'll send a pm to fordcpe and ask if he would comment on this issue.
Re: 34 cowl lamp mounted outside mirror Make the hole dropshaped or a keyway the rubber will keep it in place.
Maybe the friction from the rubberseal will take care of it as is ? |
Re: 34 cowl lamp mounted outside mirror I got a reply from Darrell, (fordcpe) He said the ones he made for his blue coupe have never moved.
Re: 34 cowl lamp mounted outside mirror 2 Attachment(s)
my roadster & the Bob Drake swan neck mirrors.
Re: 34 cowl lamp mounted outside mirror 3 Attachment(s)
The mirrors that I made for my car and my friends car have never moved. We have been on some long trips 3 to 4 hours at a time on highways at speeds of 60 to 65 mph they don't move. They are mounted between to cowl rubber gaskets Darrell
