The Ford Barn
-   -   Indicator warning buzzer (https://www.fordbarn.com/forum/showthread.php?t=211288)
DennisR 12-22-2016 01:29 PM
Solved the problem with my indicators by fitting a 535 type flasher unit, now I thought I would add a warning buzzer to remind me to cancel. Bought a ready to fit buzzer with an added warning light, pre-wired- red wire for each side and a black wire to earth. Doesn`t work on the car - the flasher unit doesn`t earth, just the standard 3 wire plug on it, should the earth go to one of the flasher unit terminals ?
DaWizard 12-22-2016 01:34 PM
Re: Indicator warning buzzer
Hey Dennis, a little more info if you would.
Is your car still 6v?
Is the buzzer 6v or 12v?
How about a pic of the paperwork that came with the buzzer, or at least a link to the paperwork.
Have you tried to hook the buzzer across your battery? And if so, did it work? with which wires used?
Need more info.
BILL WILLIAMSON 12-22-2016 01:39 PM
Try to find SIMPLE 2 wire buzzers, they're "FOOLPROOF"!
Bill Simple
DennisR 12-22-2016 01:54 PM
Bought it a while back for my Enfield Bullet and never used it. No paperwork, threw it away at the time `cause all it said was "connect a red wire to an indicator on each side and the black wire to earth" :o
I`m still running 6v, it works ok direct but doesn`t respond to the flashers which made me think could it be because the flasher unit isn`t earthed.
KGBnut 12-22-2016 02:17 PM
A lot of those are made using diodes which are polarity specific. If your car is positive-ground (positive-earth) as it came from the factory it likely won't work. Try reversing it, the black wire and one of the red wires (leave the other red wire disconnected). If it buzzes for one direction, either right turn or left turn, that is likely the problem. Unfortunately, I've never seen one of those three-wire units made for positive-ground. I made my own with an inexpensive 6-volt buzzer and a couple of diodes I bought at an electronics shop.
Ken
DennisR 12-22-2016 02:34 PM
Appreciate all replies, I thought it would be straight forward, as it was lying around thought I may as well fit it, put it back in the drawer....................
Houdini 12-22-2016 05:10 PM
I have a 12v negative ground, but what I did was ebay some cheap pizo buzzers that were two wire. I put two in, one for left and one for right. Tied the black grounds together and attached them to chassis ground. Attached the reds to the turn signal wires, which were not wired correctly based on the original diagram, but found them with trial and error. The pizos are very loud, so even with my bad hearing, I can't miss them. I tied them to the steering column with tiny black tie wraps, which is where I spliced them in to the turn signal wiring. I do like the audible signal now and because they're a bit loud, I turn them off as soon as I can.
I did a search and here is the url. Mine looks like the first one in the list, but mine was from China and shipping was free from what I remeber.
http://www.ebay.com/sch/sis.html?_nk...72.m2749.l2658
If you buy two you can reverse the wires for positive ground and they support a range of voltages. They were only a couple of bucks each at most, so maybe worth just doing that.
DennisR 12-22-2016 05:13 PM
Thanks Houdini, I`ll take a look. Managed to contact the seller of mine, turns out it won`t work on + earth.
Turns out he does the same one, 3 wire, for + earth. Ebay.co.uk no. 251607652728
CarlG 12-22-2016 05:15 PM
Those look pretty much like the buzzer I got from Snyders.
ccb360 12-22-2016 05:17 PM
For the 535 flasher (6V), connect black wire to the "P" (pilot) terminal and the buzzer red wire to ground. Only one buzzer is needed.
eagle 12-22-2016 05:52 PM
Buy a low current 5vdc buzzer off of ebay or Radio Shack. Wire it ACROSS the flasher terminals. When the flasher opens, the buzzer will sound. When the flasher is closed, no sound. Simple, low cost, effective. No need for two buzzers either. You can also buy a CLICKER that wires up identically but just gives a loud "CLICK" instead of a beep.
DennisR 12-23-2016 08:10 AM
Thank you all, as always a choice of answers to solve a problem, very much appreciated. Whilst I`m on here can I take this opportunity to wish everyone a Merry Xmas and a very Happy New Year, from Dennis, Joan and "Dilly", from over the pond..................
Gold Digger 12-23-2016 09:40 AM
I don't hear good anymore so I went with two half inch size green lights mounted in my dash. One on each side of the speedometer. My dash isn't too good anyway. Now if I forget and leave the signal on either I see it blinking or my girlfriend tells me about it.
jrelliott 12-23-2016 10:40 AM
Have a schematic for attaching a buzzer and led to your turn signals for both 6 and 12 Volts if anyone is interested. Send me an email to [email protected]
Anteek29 12-23-2016 11:55 AM
Bought a two wire from Snyders...very loud, so I wrapped it in foam to quiet it a bit.
Houdini 12-23-2016 02:22 PM
The comments about using one buzzer versus two, reminded me why I ended up using two. The previous owner didn't have the flashers wired per the diagram that came with the unit and my flasher is a 3 wire flasher. the light on the flasher control doesn't flash either. But the flasher control basically worked correctly as it's wired, so I left well enough alone and had to put a buzzer on the wire that flashed the left tail light as well as one on the right side. But yes, one buzzer should work if wired correctly in the first place.
