Spark plug for everyday My engine,has been rebuilt good compression,I easily fowl the plugs,Am I not using the spark control like I should? Or is there a better plug that will be hotter?
Re: Spark plug for everyday ????? Don't know, hard to say. Not much info.
How are using the spark ? Should be up for starting, pull down once running. Usually 1/2 to 2/3 down is fine. Depending on whether its timed right. The plugs I've found to work well are Autolite 3077. |
Re: Spark plug for everyday 1 Attachment(s)
I have about 600 miles on my eng since rebuild with a high compression head I use a champion w18y on the box it is 518/w18 I get them at napa auto parts car run great
kevin 1930 tudor |
Re: Spark plug for everyday How far open are you running the GAV, should be about 1/4 open after
engine is warm. Bob |
Re: Spark plug for everyday Maybe you are running the GAV open too far? Are you running long enough to heat the engine up good?
Re: Spark plug for everyday I use original, reconditioned 3Xs. They look great and have not caused any problems.
Re: Spark plug for everyday I am opening the gave right before I start it a 1/4 open.Spark all the way up then down 5/8 . Running Champion w16,I am not sure if that plug is to cold of a spark
Re: Spark plug for everyday Here is some information for you to read,
http://www.fordbarn.com/forum/showthread.php?t=6458 http://www.fordbarn.com/forum/showthread.php?t=6450 |
