The Ford Barn
-   -   32 original heads (https://www.fordbarn.com/forum/showthread.php?t=198441)
wadsies1 06-15-2016 07:39 AM
32 original heads
Any ideas as to what a useable pair of 32 heads are worth?? Thanks Bruce :D
Bored&Stroked 06-15-2016 02:27 PM
Re: 32 original heads
I've bought a couple sets for between $100 and $200
DavidG 06-15-2016 04:11 PM
As their survival rate is high (evidently), they are not especially hard to find. I believe what Bored&Stroked has paid to be representative of their worth. The only difference might be for a matched set of the first version with both the part numbers and "RH or LH" after the respective part number cast in or the last version without any part numbers or letters cast in. Even then, the plus side difference would likely be minor.
Ian NZ 06-15-2016 05:55 PM
I am looking for a good L.H 1932 Cylinder head, I have tried two 32 L.H. heads on my 32 V8 engine and and have found cracks on the top of them, I have had the cracks repaired on both of them by having them drilled and filled with special plugs and they are still leaking with a special additive added to the water. When they were drilled it was found both of them were very thin on top below the spark plugs. 32 cylinder heads are very hard to find here in N.Z. and I would not know how I could get a good L.H. one or even a good set shipped to me in N.Z. which I would like to obtain.
