Group 1 batteries - 6 volt for the Model A How many different ones are offered out there? Source and pricing please?
Larry |
Re: Group 1 batteries - 6 volt for the Model A Fleet Farm probably has the best price. A few years ago they were only about $30, but my friend bought one a few weeks ago and it was now $76.
There are only about 3 companies left in the U.S. that still manufacture batteries. |
Re: Group 1 batteries - 6 volt for the Model A Quote:
Our Blains Farm and Fleet here in Cedar Rapids has one on sale for $39.95 exchange. Their Blain Part Number 040573. Is this one the same as the one your friend got? Larry |
Re: Group 1 batteries - 6 volt for the Model A Interstate makes this 1-VHD 6-volt battery:
http://www.interstatebatteries.com/p...964-2147384903 I bought one 3 years ago and it's been reliable. But back then it was $78 Mike in Oregon |
Re: Group 1 batteries - 6 volt for the Model A i am a interstate stocking dealer
i have great luck with them |
Re: Group 1 batteries - 6 volt for the Model A http://www.tractorsupply.com/tsc/pro...p?cm_vc=IOPDP1
Specification Description BCI Group Size: 1 Brand: Exide Cold Cranking Amps: 625 Cranking Amps: 750 Deep Cycle/Starting: Starting Product Height: 8-5/8 in. Product Length: 8-13/16 in. Product Type: Tractor Batteries Product Weight: 27 lb. Product Width: 6-3/4 in. Reserve Capacity: 160 Terminal Type: SAE Terminal Voltage: 6 Volt Warranty: 12-Month Limited Manufacturer Part Number |
Re: Group 1 batteries - 6 volt for the Model A I prefer AC delco
interstate is 640 CCA 800 CA |
Re: Group 1 batteries - 6 volt for the Model A I have an Optima 6 volt battery. It has been very reliable for me and the car starts up right away even if it has been sitting for a couple of weeks. However, I have read that some people have experienced problems with Optima recently.
Re: Group 1 batteries - 6 volt for the Model A Ask for a Group 1 battery for 6 volts.
9 1/8 length, 7 1/8 width, 9 3/8 height 6v group 1 batteries are found by the following numbers; NAPA - BAT 7244 Exide - 7200 Tractor supply - Com 1 HP (part number 0470506) I think. Autozone - 1-6 volt Ultrapower #901MF from Deka interstate part # 1-VHD |
Re: Group 1 batteries - 6 volt for the Model A Great responses! Thank you!
Does anyone know the length; width and height of the original Model A Ford batteries? Larry |
Re: Group 1 batteries - 6 volt for the Model A Johnson controls makes a good one. Available in the Nw thru les shaub tires.
Width: 7 1/8" to 7 1/4" Length: 8 7/8" to 9" Source: Restorer Mar/Apr 1992 Volume 36-6 page 13. |
Re: Group 1 batteries - 6 volt for the Model A I have one from NAPA its about 4 years old and still holding charge well.
Re: Group 1 batteries - 6 volt for the Model A In my opinion the 6volt battery at TSC is the best value. Bought one yesterday for $65.55 out the door, how can you go wrong? Wayne
Re: Group 1 batteries - 6 volt for the Model A Why should most of the Tractor Supply battery reviews be negative? As Tom said there are only a few manufacturers making batteries so which one makes the Tractor Supply battery? I find it hard to believe only their battery would be bad.
Re: Group 1 batteries - 6 volt for the Model A I have a Tractor Supply 6 volt in my Farmall cub tractor 4 years, works great! Also have one in a 1941 Allis chalmers B it has been in it for 3 years still ok. I keep them in the basement during the winter on a battery tender. Don in Indiana. Larry we have Blains farm and Fleet in Watseka Il.
Re: Group 1 batteries - 6 volt for the Model A I've had real good luck with 6 volt batteries. In fact each one had far outlasted my 12 volt batteries. The one in my Model A came from a recycling yard more than 10 years ago and is doing fine. The Fleet Farm battery in my 1950 Studebaker was given to me as a core battery and is also more than 10 years old and doing fine.
