Coil question On a 34 V8 the owner has replaced the orginal coil at the dist with a modern coil mounted on the top of the manifold, this is still a 6 volt system and works very well but when the engine is warm it doesn't want to start,motor spins nicely with no stalls in between but it won't start, if you pull the truck it fires right up, the coil is marked Internal resistor and it is a 6 volt coil,I'm thinking it doesn't need the internal resitor but I'm not familar with the conversion from orginal coil to a modern coil.
Re: Coil question 34 has a wire resister under the dash. If that is still in the circuit , the voltage to the coil is too low.
Re: Coil question 2 Attachment(s)
Check the resistance of the coil (disconnect the wires to it and check across the terminals) and also check and see if any additional external resistors are in the circuit. The ballast resistor under the dash should not be used with this coil.
Re: Coil question I would temporarily bypass the wire wound resistor mounted behind the dash (wire & 2 alligator clips) and see what this will do for restarting the engine after it is up to normal operating temperature. If this solves the problem, jumper/bypass this external resistor more permanently.
Re: Coil question It does not need the internal resistor its a 12 volt coil Ted
Re: Coil question Hi Everyone, nothing to add but clarification...
Re: Coil question Quote:
Re: Coil question AS per instructions the resistor under the dash is out of the system.
The truck is running a6 volt coil on a 6 volt system, the only problem I can see is that the coil is marked internal resistor, I would not think that would be needed with a 6 volt system, thats what I am wondering. |
Re: Coil question It needs to be somewhere around 1.5 ohms, but your not going to know anything until you check the coil to see what it is. It's volts / ohms = amps. You need to limit the current (amperage) across the point to somewhere in the 4 - 5 amp range. 6.8 / 1.5 = 4.5 amps, 7.2 / 1.5 = 4.8 amps. A higher resistance in the coil could be limiting the current/voltage.
Re: Coil question The markings on coils is very vague ,its a 6V that you can run on 12V because it internally resisted .
Re: Coil question Let me put the question another way.
Do I need an internally resistored coil on a 6 volt system on the conversion from stock coil to modern coil keeping the system 6 volts. |
Re: Coil question Personally, I don't see any way around using JSeery's formula to get the right answer. What's MARKED doesn't matter. What is actually there does matter. JMO
Re: Coil question Why don't you get an original coil and wire it like it should be them it would
be easy to trouble shoot?? G.M. |
Re: Coil question The truck isn't here at the moment and I'm gathering info so that when I do get it here I can run thru a few checks
