The Ford Barn
-   -   Need Brakes ID'ed (https://www.fordbarn.com/forum/showthread.php?t=175278)
biggieou 08-08-2015 04:12 PM
Need Brakes ID'ed
3 Attachment(s)
Hey everyone! I have a '28 Sport Coupe with juice brakes (I didn't install) and I need to ID them. The front driverside is hanging up quite a bit and I took the drum off to back them off, but there isn't a starwheel on them to adjust, just hinges on the bottom. What are these off of and how do I adjust them so they dont hang up? Also, should there be a rubber seal on the inside of the drum?
Rowdy 08-08-2015 04:38 PM
Re: Need Brakes ID'ed
Looks like 42-48 Ford brakes. Rod
Bob C 08-08-2015 04:52 PM
There are eccentrics just below the ends of the return spring. There are two nuts
on the back side of the backing plate that you turn to rotate the eccentrics to move
the shoes in and out.
Bob
JoeWay 08-08-2015 04:56 PM
3 Attachment(s)
Yes, these are "late" flathead Ford brakes. Here are pictures of pages from an old MoTor manual with adjustment info. You won't have the factory tool, so you will have to work against your brake drum and repeat the process two or three times until you get close.
Joe
Edit--the photos don't come out big enough from the Fordbarn server to be usable. I don't have time now, but if no one else has provided better info by this evening I'll upload the photos to my website where they can be viewed at higher resolution, and provide links.
Attachment 234422
Attachment 234423
Attachment 234424
JoeWay 08-08-2015 05:41 PM
Here are links to better versions of the manual pages:
Lockheed adustment page 278
Lockheed adustment page 279
Lockheed adustment page 280
biggieou 08-08-2015 06:20 PM
Thank you gentlemen!
Randy in ca 08-09-2015 12:27 AM
1 Attachment(s)
Here's a simple, basic adjustment procedure as Bob C referred to:
