The Ford Barn
-   -   How to adjust water pump packing nut? (https://www.fordbarn.com/forum/showthread.php?t=172402)
bikemaniac 07-01-2015 12:30 AM
Hi,
I have the normal water pump. What is the correct tightness of the pack nut (the one requiring a special key). Is there a special way of adjusting it correctly?
Lucas
Henry's Lady's Man 07-01-2015 12:46 AM
Re: How to adjust water pump packing nut?
Here is a link from Snyder's, with a word of caution to tighten it gradually, and just enough to stop the leak. This is the link for the special tool.
I have an original water pump, and I bought packing off ebay, but I've never used it and dont know how. - Chuck
http://www.snydersantiqueauto.com/water-pump-wrench
katy 07-01-2015 11:00 AM
They forgot to mention that you should only tighten it w/the engine running and the pump shaft turning.
bikemaniac 07-01-2015 01:05 PM
So if I'm driving 5000 mi across USA it is just a matter of checking the nut on a daily basis and turn it a bit if it is leaking? Just continuous adjustments? What spare part do I need if I have reached the "bottom" of the nut?
Lucas
Redbird 07-01-2015 02:58 PM
More packing! Always carry a spare.
