The Ford Barn
-   -   Shock link grease fitting (https://www.fordbarn.com/forum/showthread.php?t=168258)
mshmodela 05-08-2015 07:39 AM
Last weekend I finally installed my new Stipe shock with along with new arms and new original style links --what a difference!! My question is why the original shock links do not have 2 grease fittings --1 for each ball joint... Has anyone ever added a 2nd fitting ?
Tom Wesenberg 05-08-2015 09:50 AM
Re: Shock link grease fitting
The grease should fravel to both ends with just one fitting.
Mitch//pa 05-08-2015 10:00 AM
As Tom said it works fine as designed.
No farmer fix needed
brito36 05-08-2015 12:35 PM
What's a Stripe Shock ?????
Mitch//pa 05-08-2015 01:38 PM
Stipe
CarlG 05-08-2015 01:43 PM
Originally Posted by Mitch//pa (Post 1082361)
Stipe
https://www.youtube.com/watch?v=kGwz6kafn3A
Marco Tahtaras 05-08-2015 02:30 PM
When I install the links I pack the springs and spacers with grease. Then I place a good dab of grease on each back side of each of the cups which helps 'stick' them in position. By the time you snug up the plug they are pre-lubed with the cavity full. A slight pump of grease at a later date pushes the existing grease toward both balls.
Of course you can just grease the balls and cups during assembly and then pump the link full until you see a little come out from behind each of the seals.
mshmodela 05-08-2015 05:47 PM
Yeah with Mitch's advice, I pack the spacer, spring and either back sides of the cup bearings... as well as the inner lining of the link... in short, I package about as much grease as I could before finally assembly... I thinks it's good for a while...
