Rivets Hi folks working on 30 pickup and need to rivet running board brackets not sure on which rivet tool to buy any help would be appreciated.
Re: Rivets This tool, used in a air chisel, with a torch to heat the rivets, works perfect.
http://parts.modelastore.com/show_Product.asp?ID=5765 |
Re: Rivets Thank you SteveB31 will purchase it and give it a try
Re: Rivets A 3x rivet gun is the best to use.
Re: Rivets And ear plugs! :)
