32 fuel gauge connection Hi guys
Wonder if you can help. Bought a fuel gauge line with fittings from Bob Drake (I think) - run the line and made tank connection and now 6 months later went to make the gauge connection and cant find the 'nut or olive'... Any ideas where if could buy just 1 nut and 1 olive.. Have into several engineering supply shops and they cant even agree on what I should ask for. https://www.bobdrake.com/ItemForm.as...7-ff6e68fef8b2 Any ways here a picture of the beast I'm after.. Many thanks Bruce :D |
Re: 32 fuel gauge connection Take the gauge to Napa and see if a tubing nut will fit or look up Royal Brass, they have almost any brass fitting made. G.M.
Re: 32 fuel gauge connection For 28 bucks, I'd just buy another kit from Drake and be done with it. The time/gas you spend fooling around looking for one elsewhere isn't worth it. Plus, even if you found something, you might end up with a sloppy fit on the compression fitting because the tube diameter might not be perfect for the fitting.
| All times are GMT -5. The time now is 01:31 AM. |
