The Ford Barn
-   -   Harman collins cam spec? (https://www.fordbarn.com/forum/showthread.php?t=163193)
Juniors32 03-07-2015 07:41 PM
I recently picked up a "S 109" Harman collins cam was wondering if any one had the specs on here? Any help would be great.
Thanks, rich jr
outlaw 03-08-2015 01:24 AM
Re: Harman collins cam spec?
The only information that I can find even close to a "s-109" designation is in in the vintage camshaft specifications section of the book How to Build Ford Flathead V-8 Horsepower by George McNicholl. In that section he list what is refered to as a grind called "semi" with 109 degrees lobe seperation. I don't know if that is what you have but the specs from the book are as follows: Advertised duration- 250 degrees intake & exhaust, Lobe separation angle-109 degrees, Net valve lift-.309 inch intake, .307- inch exhaust, Valve lash (hot)-.011 inch intake & .013 inch exhaust, Overlap (with advertised duration): 32 degrees, IVO: 16 degrees, IVC: 54 degrees, EVO: 54 degrees, EVC: 16 degrees. He list it as a "street cam". All the other listings that he has for Harmon & Collins have either different number or letter designations. This might not be what you have but it could give you a starting point if you can measure your lobe heights, or if you can degree your cam. I hope this helps. Bill
scooder 03-08-2015 08:12 AM
I have some specs for the Harmon & Collins semi.
Same timing events as above, but lift is. 320 in and out. They ground a "super" with. 320 lift and a "super H".350 lift could be this that the S (super) is meaning. Degreeing the cam will get us closer to what you got.
This is from. "How to hop up Ford & Mercury V8 engines". By Rodger Huntington 1951. Floyd Clymer publication.
Probably different numbers from different publications, not that uncommon when researching cams ground that far back in time.
Martin.
Juniors32 03-08-2015 05:15 PM
I have a cam card for my fathers cam which is marked s 108 and the card says sportsman on it I will take a picture and post it soon as I go out in the shop.
