The Ford Barn
-   -   Which would you use? (https://www.fordbarn.com/forum/showthread.php?t=162675)
pgerhardt 03-01-2015 02:33 PM
2 Attachment(s)
I am sitting here looking at snow falling outside AGAIN, and thinking of spring. I'll be swapping out my current distributor (with modern points and condenser on the upper plate) for a rebuilt one with the stock point system. I have the choice of two distributor body/caps. I have an old (but still in good shape) Ford script body/cap that I picked up at swap meet years ago. I also have a NORS brown body/cap which would add a little color to the engine compartment. So which do you think would be coolest?
dumb person 03-01-2015 02:56 PM
Re: Which would you use?
The brown one.
C26Pinelake 03-01-2015 03:06 PM
Why the brown one ?
Wayne
ronn 03-01-2015 03:27 PM
OK then, the black one...................
31 Model A 03-01-2015 03:44 PM
Bakelite items in other fields are worth more when the item was in brown. Don't know about this though. I'd go with the black..............for looks.
bikejunk 03-01-2015 03:45 PM
I run a brown NOS as well, for the last 2,500 miles so far, really nice quality ,
C26Pinelake 03-01-2015 04:21 PM
Originally Posted by dumb person (Post 1042696)
The brown one.
Originally Posted by 1930 coupe (Post 1042745)
I would run the one that fits the best on the distributor and has the best rotor to contact gap. Also run both of them at night in the dark and look for stray sparks.
Now that is a sensible reply ! Thanks, Wayne
BRENT in 10-uh-C 03-01-2015 04:45 PM
You mentioned a brown NOS one. Did Ford actually make a brown one?
Juggler 03-01-2015 04:49 PM
English ones are brown
Fred 03-01-2015 05:01 PM
Ok, Neither of what you show are for your car.. The "Brown One" is a After Market Reproduction one.. The "Black One" has a After Market Script Base.. The Coil Wire Tower Top is "Original Ford", But only used in Early 1928..
pgerhardt 03-01-2015 08:10 PM
No. I said NORS New Old Replacement Stock. It is photographed on the box of the company who produced it back in the day.
pgerhardt 03-01-2015 08:31 PM
1 Attachment(s)
Fine point judging aside, I would think that either could have been found on my 29 tudor in 1929. I believe that since the brown one is made of Bakelite not a modern plastic it is most likely a period replacement while a 1928 distributor body/cap could have easily sat on a dealers shelf until 1929.
In any event using the one that functions the best seems like the best and most helpful advice.
Dusty 03-01-2015 08:43 PM
Do they make them in green?
Tom Wesenberg 03-01-2015 08:49 PM
No, but you could spray paint them silver to see if the paint really contains any metal.
ODFever 03-01-2015 08:56 PM
Check both with an ohm meter. I do not know what the reading should be to determine if it's good or not, but someone here on FB might know. Pick the one that works. I'm sure you'd rather drive your car rather than being stranded on the side of the road.
pgerhardt 03-01-2015 09:01 PM
LOL! I hope that coupe has been in at least one Saint Patrick's Day Parade!:D
glenn in camino 03-01-2015 10:31 PM
Originals have only one notch to locate in the distributor base,
tbirdtbird 03-02-2015 12:01 AM
ohms should be zero
MikeK 03-02-2015 12:36 AM
Originally Posted by tbirdtbird (Post 1043092)
ohms should be zero
Following up on that thought, checking across terminals with a megger (high voltage insulation resistance tester) is also helpful. I have found several beautiful original dizzy bodies that fail internally, reading only a few thousand ohms, when I set my megger on 1KV. Checked with a standard battery powered ohmmeter they appeared fine, reading infinity between terminals.
http://core-electronics.com.au/media.../v/c/vc60b.jpg
Dusty 03-02-2015 02:34 AM
No buy I'm working on that. :)
