toyota 5 speed trans adapter. 2 Attachment(s)
THis is the modified 8BA bell housing.
Re: toyota 5 speed trans adapter. RON,
I'm not sure what you're asking, but my son & I used the following http://www.advanceadapters.com/ |
Re: toyota 5 speed trans adapter. What model and year Toyota 5 speed are you using?
Re: toyota 5 speed trans adapter. Good Job Ron. Walt
Re: toyota 5 speed trans adapter. This is behind the 294 ci engine and works fine. The trans is a W55 or w56. It's the one with the aluminum case and is very heavy. much heaver than the RTS.
So ya don't have to spend a fortune to install one of these. Remember the wright bros couldn't call up Boeing. |
Re: toyota 5 speed trans adapter. Capn John
I'm old and don't see very well. I also am computer challenged. But I thimk the persons that made tat web site, must have worked for the Government, can't find a list of adapters and prices. |
Re: toyota 5 speed trans adapter. Ron i think this is a great idea. For one there are going to be a ton of these trans in junk yards and t5s are already getting expensive. Maybe ahead of the curve!
Re: toyota 5 speed trans adapter. MIKE DAVIDSON of flatattack racing does a nice toyota 5 speed adapter for w55 and w56 gearboxes for 59a engines not sure about 8ba www.flatattackracing.com He makes some nice stuff check out his web site
Re: toyota 5 speed trans adapter. I googled the ratios on the W55 and W56 and they appear to be very similar to the .86 ratio T-5.
Re: toyota 5 speed trans adapter. I know Mike, he makes a nice cylinder head.. This would have to be a home made unit to save any money or use his and a Merc or PU bell housing with the aftermarket units. I was only trying to help others make this kind of adapter. I also made one for the RTS
| All times are GMT -5. The time now is 11:18 PM. |
