30 roadster curtain pan, seat pan...hardware Hi all,
I need to know the correct hardware to install these metal floor pans? Nothing seems to show up in the books I have. I basically need the hardware for all the metal floor pans in a roadster. Thanks for any help. Tom |
Re: 30 roadster curtain pan, seat pan...hardware They were rivited to the sub frame. If you still have the original body subframe then you should be able to locate the holes.
Re: 30 roadster curtain pan, seat pan...hardware Thanks Doug... I do and see the holes.
Anyone know where I can buy these rivits/tools? |
Re: 30 roadster curtain pan, seat pan...hardware I believe Bratton's sells them
