The Ford Barn
-   -   Water pump shaft loose (https://www.fordbarn.com/forum/showthread.php?t=11738)
Dave / Franklin MA 08-25-2010 10:31 AM
My water pump shaft moves forward and back 1/8 to 1/4 inch, that seems excessive. It makes a dull tapping noise. Packing nut is snug and it doesn't leak. Does it need more packing material? What is supposed to take up the slack? Is there something else I should check?
BRENT in 10-uh-C 08-25-2010 10:42 AM
Re: Water pump shaft loose
There is likely a problem inside the head where the pump shaft rides. Often times this is worn. A quick fix for you is to purchase a collar that fits on the front of the pump underneath the pulley on the fan. Look up part number 12500 on the Bratton's website.
http://www.brattons.com/uploads/imag...arge/12500.jpg
glenn in camino 08-25-2010 10:44 AM
You need a waterpump collar on the shaft, under the fan, to limit endplay. Waterpump collars are available from all Model A parts supplyers.
TinCup 08-25-2010 11:12 AM
One of the guys in the local club had a two piece that you could put just behind the packing nut to limit the back and forth play. Didn't need to pull the fan to install.
d.j. moordigian 08-25-2010 11:19 AM
TinCup,
" behind the packing nut ", I think that's WRONG. The only thing behind is the bushing.
Dudley
TinCup 08-25-2010 11:57 AM
Yeah I thought that two. The guy that installed the two piece pulled the shaft out toward the radiator. Then placed the collar behind the packing nut. It rides against the back of the nut and keeps the shaft from moving back and forth. I used the collar shown on mine.
Purdy Swoft 08-25-2010 02:43 PM
Could you mean in front of the packing nut? That would work.
Dusty 08-25-2010 04:58 PM
This two peice collar can be purchased from Granger, it was about 8 or 9 bucks.
worked for me.
dusty
