The Ford Barn
-   Model T (1909-1927) (https://www.fordbarn.com/forum/forumdisplay.php?f=2)
-   -   What have I got ? (https://www.fordbarn.com/forum/showthread.php?t=10959)
0rg0 08-16-2010 06:25 PM
What have I got ?
Hi all,
I just got myself a Model T coupe body. Not much left of it, but it has the doors, which I hear is a good thing. I know it's a later one, but does anybody know of any features that would tell me what year it is ? I will post some pics as soon as I get it out of the bush.
Model T Monte 08-16-2010 09:49 PM
Re: What have I got ?
Orgo, a 26-7 will have the gas tank in the cowl under what looks like a cowl vent.
0rg0 08-21-2010 12:28 PM
4 Attachment(s)
Here it is.
Model T Monte 08-21-2010 01:40 PM
Orgo, you are the owner of a 26 coupe bodie. Congrats, I don`t have one of those yet. Monte
0rg0 08-21-2010 02:02 PM
How can you tell it's a '26 ?
Model T Monte 08-21-2010 03:55 PM
Orgo, The fuel tank is in the cowl section, the firewall is different to early models. There are several distinguishing signs, I`m still learning. Monte
FL&WVMIKE 08-22-2010 11:56 AM
OrgO ...........................
That body is in such good shape, in spite of some rust, you just wonder what happened to the rest of it. ???? Is that original paint ?
I hope that you are a restorer and not a rodder. You can make it happen.
MIKE :)
Roadster62 08-22-2010 04:23 PM
It could be a '27 as well, you have to deside if you like 26 better than 27.
0rg0 08-23-2010 01:53 PM
yeah, it looks like some original paint on it. The body is super solid. Sub frame is near perfect. The bottom 2" or so all the way around is rusted through, but it's all pretty much flat steel. Should be a pretty easy fix. I was also wondering why a car in good shape would be stripped. Maybe a previous owner took it apart to repair it ? As for restoring vs rodding. Not sure yet. It's missing lots of stuff. I do have a Model A frame, and some '39 suspension parts. So they might be used on this. For now, I'll just work on the body, and see what parts I can come up with.
I had heard that 1926 models had wood inner frames around the windows, and 27's were steel, so I'm thinking it's a '27.
0rg0 08-31-2010 06:26 PM
Well, I just got another one. A '26 this time. It has all the bits I need including a near perfect driver door. No rust. amazing. Has a workable trunk lid, and lower panel. Has the header panel. I almost have a complete body. Only missing the visor, and a wind sheild frame. The rest of it is pretty rusted out. I will have an extra set of repairable doors however. If anybody needs them, I would trade for other T parts.
southfork 08-31-2010 07:25 PM
OrgO, I could use the extra set of repairable doors you got. What are you looking for in trade? I've got lots of Model T and A stuff. PM sent!
-jack
Jack Innes 09-01-2010 07:25 PM
If you still need it there is a ready to instaLL 26/27 firewall on the "Non-Chevy Guys" site under the Swap Meet category.
stingraydriver 12-14-2010 09:53 AM
OrgO, Just a short note to see if you still have the exta dooirs or if you have traded them off.What model T parts do you need? Thanks for your [email protected]
