Y-Block bellhousing.... Found one. Thank you. City:
Langhorne
State:
PA
Found one.
Thanks....Mark |
Re: Y-Block bellhousing from a Ford truck with a 3 speed Whats the difference from a 56 with a 4 spd.
Re: Y-Block bellhousing from a Ford truck with a 3 speed Quote:
Re: Y-Block bellhousing from a Ford truck with a 3 speed I have a Y block bell and a 3sp. truck trans, also 3sp car trans. let me see what the bell bolt pattern will fit, it may be a few days before I unload my trailer, just got home from a 3 day show/swap meet, everthing is still packed, and i'm tired. I will check and let you know. Ken in Va.
Re: Y-Block bellhousing from a Ford truck with a 3 speed I did measure the bell tonight and I have a car bell, much smaller bolt pattern than a truck. The truck is 8-1/2 top and bottom, 7-1/4 both sides. car is 7-1/4 both sides but 5-1/4 top and 6-1/4 bottom all measurements are center to center on the bolt holes. This may help other's that are looking at bell housings.
Re: Y-Block bellhousing from a Ford truck with a 3 speed i have 2 ford y block 3 speed bell housing for sale george 406-5432591
Re: Y-Block bellhousing from a Ford truck with a 3 speed i have one too.25.00 plus shipping
Re: Y-Block bellhousing from a Ford truck with a 3 speed Hi, I need a car bell?? Thx, Tom
| All times are GMT -5. The time now is 10:02 AM. |
