The Ford Barn
-   -   seatbelts for my '32 pickup (https://www.fordbarn.com/forum/showthread.php?t=101979)
Sal ModelA 03-31-2013 11:26 AM
Hi Guys,
I'm not saying that I drive fast, but hey, it is a Ford V-8. A few of my nervous (male) passengers have been saying that I should fly lower and put (airline?) seat belts in the old pickup. In deference to their white-knuckling, I am considering it. But I don't know what to latch on to, considering that the gas tank is under the seat. Has anyone else had this issue and found a solution?
Thanks for helping a gal out.
(high flying) Sal
al's28/33 03-31-2013 11:37 AM
Re: seatbelts for my '32 pickup
In my '33 I was able to bolt them thru the back side of the seat riser. Maybe you can bolt on the bottom of the cab in the space between the tank and rear wall. They should be long enough to reach up and over the tank then slip thru the seat cushions.
Clem Clement 03-31-2013 12:13 PM
My ' peeekup 39 has them plus the shoulder straps as well. Momma feels safer.
Sal ModelA 03-31-2013 03:39 PM
Hi Guys,
Is it a good idea to anchor the ends to the bottom of the cab, which is just sheet metal? There must be a better and more secure place. If in sheet metal, how about backing using a long metal plate, say 4 inches by 12 inches?
Thanks for your input.
(grounded for now) Sal
2ndgeer 03-31-2013 04:36 PM
1 Attachment(s)
I've installed seat belts in two '34 Ford pickups and a 1950 Ford pickup. I used Juliano's kits including the backing plates beneath the cab floor. I recommend the step drill for the sheet metal if you don't know about it. Here's a step drill.
Kube 03-31-2013 06:48 PM
There was very recently a long thread in regard to belts in our old Fords. Perhaps it may make sense to read and digest the various opinions.
Unless the belts are installed correctly, they may cause more harm in an accident than good.
Bolting them to any sheet metal is dangerous. Even with large washers, they will rip the surrounding metal out faster than you can blink.
1932BB 04-01-2013 07:32 PM
Seatbelts? I don't use 'em! Takes longer to get out on the running board and jump!
2ndgeer 04-02-2013 12:47 PM
Think about this. Early Fords are "body on frame" so you DON'T want to attach the belt mounts to the frame!! In case of a serious accident where the body may be separated from the frame you are better off "staying with the body."
Kahuna 04-02-2013 04:42 PM
2 X 2ndgeer
He's got it right
Kube 04-02-2013 05:36 PM
I will agree with this.
So, the bottom line remains... these cars are not designed for belts and the installation achieves little more than some "feel good" for the driver. In reality, you do not want to be involved in a serious accident in one of these cars... period.
woodypecker 04-02-2013 09:06 PM
http://www.fordbarn.com/forum/search...archid=2722662 try this link.
OldDad 04-02-2013 10:40 PM
I'll go with something to slow my head down on its way to the metal dash. I don't expect to survive any head-on collisions. So, three point belts for me. Seat goes with you though, so pick your own poison!
