31' Generator not charging Well I tried to lower my generator output from 12A to something less but appears I've likely made things worse. Before I yank the generator and have at it figured I'd toss what I'm seeing:
Ammeter: At idle, 0A. At speed no charging.. I do see 1-3A when I step on the breaks (load).... Wondering if there some way I might the generator output less the cutout... http://www.modelaford.org/technical/...amcolor2sm.jpg |
Re: 31' Generator not charging Have you adjusted the third brush?
Charlie Stephens |
Re: 31' Generator not charging If you moved the third brush, how much did you change it ? Have you tried different settings ?
Re: 31' Generator not charging Yeah I have a 3rd bush but it's very hard to move...
Re: 31' Generator not charging Taken the Generator off... simple enough for that... my 3rd brush ring is frozen so only one what to see that's up.... I'll make some video of this... soon... :)
Re: 31' Generator not charging Armature:
https://www.youtube.com/watch?v=IXU9U6cGl68 So as my Generator rebuild from fmr. owner, a likely new armature, but 3rd bush ring, and field windings have been around for a while.... |
Re: 31' Generator not charging So got the end cap off and 3rd brush ring just stuck due to old oil,dirt, etc.. I've got it off so it needs a cleaning...
End cap and 3rd ring: https://www.youtube.com/watch?v=94j8doUPgGY I took very fine file and removed to two spurs on the ring... now I have full range of motion on my 3rd bush ring... https://www.youtube.com/watch?v=yYlpy75GdA4 |
