Round speedometer recalibrating One of my "A's" with a round speedometer works fine but reads 45 when I'm only going approximately 35 mph. Is there some way to recalibrate rather than send it off and get it rebuilt?
Re: Round speedometer recalibrating Have you checked the odometer for accuracy on a measured mile ?If it is accurate the problem would be in the speedometer. If it is also reading high,(more than a mile),you may look into installing a larger speedometer drive gear to slow it down.
Re: Round speedometer recalibrating Do you have the correct size tires/wheels on it? That will also throw it off. Good Luck
Re: Round speedometer recalibrating I've got the right size tires and wheels but I haven't checked the odometer. I'll do that.
Re: Round speedometer recalibrating I fount this very helpful getting my speedo working. My speed is accurate the odometer not so much compared to a GPS.
http://www.modelahouse.com/tech/spee...r/fischer.html |
