Another illustrated comparison request for '35/'36 rear fenders Does anyone have, or know where I can find, an illustrated overlay picture of a coupe/roadster/cabriolet rear fender compared to a sedan rear fender, for either '35 or '36? I know I have seen something like this before. I also know the coupe rear fenders are about 2" wider than sedan rear fenders at the top/center area, and I can personally tell the difference when looking at these fenders at swap meets, etc., but sometimes this can be difficult to explain to someone else without having samples of both to show the difference. Having an overlay picture would be the next best thing, and probably worth a thousand words.
Re: Another illustrated comparison request for '35/'36 rear fenders 1 Attachment(s)
John, I marked up this photo a few years back. Hope it helps.
Don |
Re: Another illustrated comparison request for '35/'36 rear fenders That's what I remembered seeing. Thank you Don!
Re: Another illustrated comparison request for '35/'36 rear fenders Easiest way to pick up a fender at a swap meet and know what it is is:
7 mounting holes coupe, 8 for sedan Quote:
Re: Another illustrated comparison request for '35/'36 rear fenders A trunk back is different, at the rear to a flat back ,Like longer! ,Ted
Re: Another illustrated comparison request for '35/'36 rear fenders Ted, All 35 sedan rear fenders are the same. There is no difference between trunk back and flat back.
Regards, Don |
Re: Another illustrated comparison request for '35/'36 rear fenders Don ,I have experienced this in comparing 35 fenders, if its not the length then there's a different shape at the rear .There's a indicator it in the 35/36 book On a trunk back touring sedan the body is 185.1/8 ,longer as opposed to the flat back 182.3/4 .Because the body is longer so I think the rear fender has to be to line up with the bumper, there is that extension on the chassis that makes it 2,3/8 longer . Ted
Re: Another illustrated comparison request for '35/'36 rear fenders 2 Attachment(s)
Are these coupe fenders
Re: Another illustrated comparison request for '35/'36 rear fenders Please show the shape of the last 12 inches at the rear where they attach to the tailpan.That is where the major difference lies,I believe.
Re: Another illustrated comparison request for '35/'36 rear fenders They do have 7 mounting holes, measuring were Don had measured I think.
Re: Another illustrated comparison request for '35/'36 rear fenders 6 Attachment(s)
Bumping this one back up to add a few pictures and identification help. As well as being wider and having a different number of over the top mounting holes, the coupe/roadster/cabriolet fenders have a much longer inside mounting bracket on the tail section with more mounting holes (3 or 4) than the sedan/phaeton fenders have (2). As long as these brackets are intact, it should take no more than a glance to differentiate between these two fender types.
Re: Another illustrated comparison request for '35/'36 rear fenders Quote:
Re: Another illustrated comparison request for '35/'36 rear fenders Thank you ,You sure answered the questions about the fenders.
