48 coupe- 59AB engine what are these holes for? 2 Attachment(s)
Two 3/8-16 threaded holes adjacent to left and right water pumps. What are they for?
Re: 48 coupe- 59AB engine what are these holes for? They're so you can use the 59 block as a "replacement block" in a '32. DD
http://www.fordbarn.com/forum/attach...5&d=1468945745 |
Re: 48 coupe- 59AB engine what are these holes for? Ya think?
Re: 48 coupe- 59AB engine what are these holes for? Quote:
Re: 48 coupe- 59AB engine what are these holes for? I think so !
Re: 48 coupe- 59AB engine what are these holes for? There is a photo in one of the reprints of Ford service bulletins showing a lift fixture bolted to those same holes to remove and install engines in the '38-'47 COE thru the front of the truck.
Mark |
Re: 48 coupe- 59AB engine what are these holes for? 8ba's have those holes also
Re: 48 coupe- 59AB engine what are these holes for? In '53 they were again used for a saddle mount for pickups and larger
Re: 48 coupe- 59AB engine what are these holes for? It appears those same holes are likely used in this pictured operation. Upon second look, these all appear to be POST-'48. Probably on their way to, or coming back from being "spun" by the big electric motors. DD
http://www.fordbarn.com/forum/attach...4&d=1477844295 |
Re: 48 coupe- 59AB engine what are these holes for? Thats it..... hang 'em from the end.... so they dont sag from sitting horizontal... Mark
