NEW PICS Added! Help! Pines Winterfront grill info needed 2 Attachment(s)
I'm hoping someone can identify this Pines Winterfront accessory. I was told it fits 35-37 Fords but all of the 36's I've seen are on the outside. This looks like it goes on the inside. Roughly measures 24" L X 16" W with the " ears" . The shutter box alone is 20"X10". Has Pines water decal on top and a lever that looks like a cable connects to it to open the shutters. Ear's seem to be sloping back or contourable. Cannot find numbers on the unit or where to look. Help if you can. Thanks
Re: Help! Pines Winterfront grill info needed bttt
Re: Help! Pines Winterfront grill info needed Your pics are to small to tell.
Re: Help! Pines Winterfront grill info needed Resize your pics to a larger size, they will show up better then as Deuce lover suggests.
Re: Help! Pines Winterfront grill info needed I can resize them larger but still can't make out much detail due to the quality of focus/lighting on these shots.
Re: Help! Pines Winterfront grill info needed Quote:
Re: NEW PICS Added! Help! Pines Winterfront grill info needed prewar, I have never seen one like that. I'm sorry to say, I have no idea what it could be for. However, someone here or maybe on the efv-8c/a website should be able to tell you what that is for.
Re: NEW PICS Added! Help! Pines Winterfront grill info needed Someone was selling one of these for a '36 on ebay a while back, he ended the auction early. I was planning to bid.... You can still see the auction, but i'm sure epay will pull it down soon.
http://cgi.ebay.com/ws/eBayISAPI.dll...c#ht_500wt_922 Neat to see the original switch and other pieces, yours (and the ebay one) are the only ones i've ever seen. Todd |
Re: NEW PICS Added! Help! Pines Winterfront grill info needed bump
Re: NEW PICS Added! Help! Pines Winterfront grill info needed Perhaps you should take into consideration that it does not fit a Ford product. Most likely something like a narrow snout 36'-39' Chev.
After all they made them for many different brands. |
Re: NEW PICS Added! Help! Pines Winterfront grill info needed bttt
Re: NEW PICS Added! Help! Pines Winterfront grill info needed i just acquired one exactly like this and found this post in my quest for information. if you've found out anything, please post it!
