Torsion Rod ends / Drag Link Steering Arm end In the process of working on the front end and when I opened the Torsion Rod ends / Drag Link Steering Arm ends and found the spring was placed directly against the back wall of each ball holder without the thin cup. Is there supposed to be a thin cup between the back wall and the spring?
Thanks Bob |
Re: Torsion Rod ends / Drag Link Steering Arm end Yup. Snyders has a great drawing on their website. Are the balls nice and round?
Re: Torsion Rod ends / Drag Link Steering Arm end The steering arm balls are worn enough to need to be replaced.
Re: Torsion Rod ends / Drag Link Steering Arm end Bratton's has some pictures at this link. https://www.brattons.com/original-st...build-kit.html
Re: Torsion Rod ends / Drag Link Steering Arm end At one time there was a greaseless hard Teflon cup kit available for shock arms and steering. Does anyone know if it is still available and where?
Re: Torsion Rod ends / Drag Link Steering Arm end Quote:
Re: Torsion Rod ends / Drag Link Steering Arm end Remember, the drag link ends are different. The pittman arm end is different from the other end. The drawings show this but they don't notate it. The tie rod ends are the same.
Regards, Stew |
Re: Torsion Rod ends / Drag Link Steering Arm end Many thanks- the Bratton’s pictures are very helpful
Bob |
Re: Torsion Rod ends / Drag Link Steering Arm end Thanks
