35/36 rear floor cross member On my 36 there is a floor subrail that is riveted to the wheel wells on both sides and runs under the floor. There are 2 bolts that evidently run through this subrail and into the frame. My question is this. Was there originally wood inside this C channel subrail? Thanks
Re: 35/36 rear floor cross member Quote:
Re: 35/36 rear floor cross member I thought it looked like a logical place for wood. Thanks
Re: 35/36 rear floor cross member I'll try and get a picture of it, but as I recall, there were (2) wooden blocks, one in each side, of that channel and a long bolt went through the floor pan (behind the side supports in the trunk area) and through the wooden block and were secured with a hex nut. The (2) bolts acted as a body mounting bolt.
There was not a single, long piece of wood from one side to the other. This was on my '36 3W. -Bob |
Re: 35/36 rear floor cross member Thanks Bob!
Re: 35/36 rear floor cross member Here's pics of the spacer blocks on the bench and also installed in the channel.....
http://i443.photobucket.com/albums/q...ps7ucuroyd.jpg http://i443.photobucket.com/albums/q...psyyuv2tf6.jpg Note that one side of the block is cut on an angles to conform with the angle of the channel. If need be, I can remove one of the blocks and measure it for you. -Bob |
Re: 35/36 rear floor cross member Perfect! That helps a lot. Thanks Bob
Re: 35/36 rear floor cross member Tagman - wouldn't happen to have dimensions for the wood blocks would you?
Re: 35/36 rear floor cross member 1.5" width. I think I have some scrap oak that will work well
Re: 35/36 rear floor cross member 1 1/4" wide x 2 15/16" long. They go in the floor channel which is on the descending side of the frame beyond the rear axle so they have a sloping side. The height on one side is 1 3/16" and on the other side is 2". There is a 7/16" hole for the bolt. These blocks are a left and a right, so the hole is in 1 1/16" from one end for one side, and 1 1/16" in from the other end for the other side.
Re: 35/36 rear floor cross member Good stuff. Thanks all.
Re: 35/36 rear floor cross member Does anybody commercially make these blocks? Thanks.
