Original 1931 Coupes and Roadsters with trunk compartment... If there is anyone or someone that knows of anyone who has a an original (unrestored) 1931 Coupe or Roadster with a trunk, we need to confirm the SHAPE of the Deck Door Lock Striker Plate.
There seem to be two styles (maybe more) one style has a symetrical appearence (the most common one seen) and the other has a non-symetrical appearence (not sure if this one is original to the Model A Ford, a later Ford issue or reproduction). With that were the original 1931 striker plates symetrical or were they non-symetrical in appearence? Thank you. Pluck |
Re: Original 1931 Coupes and Roadsters with trunk compartment... I have a '30 original with trunk lid - will a check of that one qualify or do you have to see a '31?
Re: Original 1931 Coupes and Roadsters with trunk compartment... 2 Attachment(s)
May 1931 Original Coupe.
Does this help. .. |
Re: Original 1931 Coupes and Roadsters with trunk compartment... Quote:
But I think Steve's also looking for photos.. Thanks,...Dudley |
You bet it helps...Thank you. If you could, could you please send it to me at [email protected]? Anyone else out there with 1931 Trunk compartments later than may 1931? Thanks. Pluck |
Re: Original 1931 Coupes and Roadsters with trunk compartment... Not to hijack the thread, but since Pluck and I are working on the same project, I would also ask that if someone has and original 29 striker, a photo would answer a lot of questions.
Re: Original 1931 Coupes and Roadsters with trunk compartment... Pictures send
My Coupe has an indented firewall. ... |
here are the two types that we have found so far
we need owners of original trunk cars to respond so that Pluck can finish up the article tom |
Re: Original 1931 Coupes and Roadsters with trunk compartment... This is a pic that Jim Sinclair posted of his original '28 Roadster. It is clearly the symmetrical type. Rusty also posted a pic of another original '28 Roadster and it was the same.
http://www.fordbarn.com/forum/attach...8&d=1422239809 |
