On the road again with mitchell overdrive! It's been a year and a half start to finish for what I wanted to get done this time. The list included installing a new Mitchell overdrive.
Took some Photos for anyone who may be considering using Mitchell. [IMG]https://fordbarn.com/forum/picture.ph...ictureid=34891[/IMG] old removed [IMG]https://fordbarn.com/forum/picture.ph...ictureid=31072[/IMG] [IMG]https://fordbarn.com/forum/picture.ph...ictureid=31069[/IMG] New Parts! [IMG]https://fordbarn.com/forum/picture.ph...ictureid=34892[/IMG] adapter overdrive to rear [IMG]https://fordbarn.com/forum/picture.ph...ictureid=34893[/IMG] overdrive to rear [IMG]https://fordbarn.com/forum/picture.ph...ictureid=34896[/IMG] adapter driveshaft to overdrive [IMG]https://fordbarn.com/forum/picture.ph...ictureid=34898[/IMG] unit installed floor uncut [IMG]https://fordbarn.com/forum/picture.ph...ictureid=34899[/IMG] up on lift floor to overdrive [IMG]https://fordbarn.com/forum/picture.ph...ictureid=34900[/IMG] side view on floor [IMG]https://fordbarn.com/forum/picture.ph...ictureid=34901[/IMG] Rear view on floor [IMG]https://fordbarn.com/forum/picture.ph...ictureid=34903[/IMG] floor altered for overdrive unit [IMG]https://fordbarn.com/forum/picture.ph...ictureid=34902[/IMG] shifter installed |
Re: On the road again with mitchell overdrive! Pictures please!!
Re: On the road again with mitchell overdrive! We have had a Mitchell in our 46 for 3 years now and love it after almost 8000 miles. Enjoy
John |
Re: On the road again with mitchell overdrive! did you have to cut the floorpan. and what rear ratio have you fitted
thanks Lawrie |
Re: On the road again with mitchell overdrive! I order the shifter that was to attach to the stick shift but with a curved shift lever the unit would not work thought this would work here and it does.
The install was not that hard and if I was to only install the overdrive it would have only taken a few days. |
Re: On the road again with mitchell overdrive! OK looks like photos are not showing up, hope to get them posted soon
Re: On the road again with mitchell overdrive! Pictures are showing up fine for me. I know you will enjoy the Mitchell. Which ratio did you use?
Re: On the road again with mitchell overdrive! Looks like a great job. If you can see these pictures they are a GearVendors unit installed in '04 now has 20k trouble free miles. I did have to widen the tunnel about an inch to accommodate the unit. Works great. With 3:78 rear it tachs 2700 rpm @ 70mph. Good luck
Re: On the road again with mitchell overdrive! No pics here
Re: On the road again with mitchell overdrive! no pics for me .
Re: On the road again with mitchell overdrive! Quote:
Re: On the road again with mitchell overdrive! Nicely done - certainly a great way to retain the torque tube and a viable option vs a T5 setup .....
