Ford factory / dealer service tool 4 Attachment(s)
Anyone know what its for. Im guessing 1960s era
Has fomoco and a part number |
Re: Ford factory / dealer service tool Transmission band adjustment tool.
Re: Ford factory / dealer service tool 1 Attachment(s)
Hi Everyone! Skidmarks it seems to be a holding tool and thickness gauge for late 50's early 60's Ford 2 speed automatic transmission..
Referenced here: https://www.jalopyjournal.com/forum/...-matic.990213/ And here: https://www.fixya.com/cars/t15136643...park_1962_ford https://www.fordbarn.com/forum/attac...4&d=1594391113 |
Re: Ford factory / dealer service tool Did a search and it looks like it is for adjusting the rear band on transmission.
http://restorecarsclassifieds.com/wi...df.pdf?n=15424 |
Re: Ford factory / dealer service tool Thank you
Re: Ford factory / dealer service tool It's for: COMET, EDSEL, FALCON Ford 2-Speed Auto Trans 1959-60.
Copied and pasted: Rear Band (Reverse Range): Drain transmission and remove oil pan and screen. Loosen rear servo piston rodlocknut and adjusting nut, then install tool as follows:If Ford Tool T59P-77409-A used, place tool on rearservo rod so two forks straddle band apply lever.NOTE • The inner fork must engage flat on servo pist nrod. The outer fork is a %" spacer and must be insertedbetween piston rod seat and adjusting nut. If Edsel Tool7355-A used, insert tool between adjusting nut andpiston rod-to-actuating lever seat, with opposite endof tool resting on raised boss on control valve assembly.With wrench T59P-77423-A (Ford), or No. 7355-B(Edsel),tighten adjusting nut until wrench handle snaps (breaks)over center. NOTE - These tools are pre-set torquewrenches which overrun when torque on screw reaches45-50 inch pounds. Back off adjusting nut exactly twtums. Hold adjusting nut at this position and tightenlocknut to 15-18 ft. lbs. Remove tools from servo pistonrod. Install oil pan and screen using a new gasket. Filltransmission with Automatic Transmission Fluid Type"A" You can buy another one "NOW" on eBay for $29.41. DD |
